Home » Modeling » TMF (Xtext) » Xtext Proposal Provider: Remove "super" etc. from list
Xtext Proposal Provider: Remove "super" etc. from list [message #1779917] Mon, 15 January 2018 14:12 Go to next message
I'm trying to customize my Proposal Provider for my dsl written in Xtext with Xbase.
What I got working is to remove some default keywords (like throw) with the following code:
override completeKeyword(Keyword keyword, ContentAssistContext contentAssistContext,
		ICompletionProposalAcceptor acceptor) {
			//Ignore these
		if (keyword.getValue().equals("switch") || keyword.getValue().equals("var") ||
			keyword.getValue().equals("for") || keyword.getValue().equals("val") || keyword.getValue().equals("val") ||
			keyword.getValue().equals("try") || keyword.getValue().equals("throw") ||
			keyword.getValue().equals("synchronized") || keyword.getValue().equals("this")) {
			return;
		super.completeKeyword(keyword, contentAssistContext, acceptor);
But I want to remove the default proposals "super" and "this" primarily. It would be great to also remove some variables by name (like "args" from the generated java main method) but that would be optional.
Is there a way to remove these?
Thanks in advance.
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1779922 is a reply to message #1779917] Mon, 15 January 2018 14:26 Go to previous messageGo to next message
do you want to remove these from proposals only or from the scoping as well (hey originate from there) see usages of the constants in org.eclipse.xtext.xbase.scoping.batch.IFeatureNames
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1779924 is a reply to message #1779922] Mon, 15 January 2018 14:36 Go to previous messageGo to next message
have a look e.g. at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.addThisAndSuper(IFeatureScopeSession, ITypeReferenceOwner, JvmDeclaredType, JvmTypeReference, boolean)
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1780021 is a reply to message #1779924] Tue, 16 January 2018 10:11 Go to previous messageGo to next message
Thanks for your input.
I had a look at the classes and tried to overwrite addThisAndSuper by removing the builder.add(THIS) and builder.add(SUPER), but it didn't work.
It would be sufficient if they just wouldn't appear in the proposal anymore. Where would I have to look at for this?
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1780024 is a reply to message #1780021] Tue, 16 January 2018 10:17 Go to previous messageGo to next message
did you have a look at other places?
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1780030 is a reply to message #1780024] Tue, 16 January 2018 10:38 Go to previous messageGo to next message
btw why do you want to get rid of "this"?
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1780031 is a reply to message #1780030] Tue, 16 January 2018 10:57 Go to previous messageGo to next message
besides this you can try something like
public class DomainModelFeatureScopes extends FeatureScopes {
	protected IScope createLocalVariableScope(EObject featureCall, IScope parent, IFeatureScopeSession session,
			IResolvedTypes resolvedTypes) {
		return new LocalVariableScope(parent, session, asAbstractFeatureCall(featureCall)) {
			public IEObjectDescription getSingleElement(QualifiedName name) {
				if (IFeatureNames.THIS.equals(name) || IFeatureNames.SUPER.equals(name)) {
					return null;
				return super.getSingleElement(name);
			protected List<IEObjectDescription> getLocalElementsByName(QualifiedName name) {
					return Collections.emptyList();
				return super.getLocalElementsByName(name);
			protected List<IEObjectDescription> getAllLocalElements() {
				return IterableExtensions.toList(Iterables.filter(super.getAllLocalElements(), new Predicate<IEObjectDescription>() {
					public boolean apply(IEObjectDescription d) {
						return !IFeatureNames.THIS.equals(d.getQualifiedName()) && !IFeatureNames.SUPER.equals(d.getQualifiedName());
or move the filtering to
org.eclipse.xtext.xbase.ui.contentassist.XbaseReferenceProposalCreator.queryScope(IScope, EObject, EReference, Predicate<IEObjectDescription>)
Re: Xtext Proposal Provider: Remove "super" etc. from list [message #1780038 is a reply to message #1780031] Tue, 16 January 2018 12:30 Go to previous message
Thanks, that example works perfectly fine!
I don't want to use "this" and "super" in my language because its a language without object instantiation. Its a imperative language for beginners. I wanted to remove it from the content proposals because it might be confusing for beginners in coding to see them and get confused because they don't get used in the language.
Previous Topic:Debug "Produced region is inconsistent"
Next Topic:xText Standalone maven dependencies
Current Time: Fri Jul 25 08:36:45 EDT 2025
Powered by FUDForum. Page generated in 0.51217 seconds
