Annoted Java generation broken in latest EMF? [message #1779518] |
Tue, 09 January 2018 02:05  |
I recently updated my dev environment from Eclipse Mars to Oxygen, and with it moved from EMF 2.11.2 to EMF 2.13.0. Now when I try to reload/regenerate my model code from annotated Java, it doesn't work anymore.
Specifically, I have a model in project A:
package com.model.version
import org.eclipse.emf.ecore.EObject;
* @model abstract="true"
public interface VersionedModel extends EObject {
* @model suppressedSetVisibility="true" default="0"
public int getModelVersion();
and then a child model in project B: (This is important. It only seems to break when the child model is in a different project).
package com.ui.model.color;
import com.model.version.VersionedModel;
public interface IColorPalette extends VersionedModel {
Once I generate my ecore models from my annotated java, and generate my code the result is that IColorPaletteImpl extends EObjectImpl, when it should be extending VersionedModelImpl.
This worked fine in our previous version of EMF, but stopped working with the new upgrade. Also, if I manually configure my Ecore model to define IColorPalette's supertype, the code generates correctly. However, as soon as I regenerate the Ecore model from the annotated java, it resets back again.
Is there some new detail in the latest versions of EMF that we're missing?
Re: Annoted Java generation broken in latest EMF? [message #1779801 is a reply to message #1779716] |
Fri, 12 January 2018 16:25  |
I've posted the bug as you suggested here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=529776
There is indeed a difference between the ECORE generated by annotated java, and the ECORE that is manually configured.
Annotated Java version:
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="color" nsURI="http:///com/ui/model/color.ecore" nsPrefix="com.ui.model.color">
<eClassifiers xsi:type="ecore:EClass" name="IColorPalette" abstract="true" eSuperTypes="#//VersionedModel"/>
<eClassifiers xsi:type="ecore:EClass" name="VersionedModel" instanceClassName="com.model.version.VersionedModel"
abstract="true" interface="true"/>
</ecore:EPackage>
Manually Configured version:
<eClassifiers xsi:type="ecore:EClass" name="IColorPalette" abstract="true" eSuperTypes="../../com.model/model/version.ecore#//VersionedModel"/>
</ecore:EPackage>
FUDForum. Page generated in 0.06091 seconds
