Home » Modeling » TMF (Xtext) » Use object as type instead of String
Use object as type instead of String [message #1779350] Fri, 05 January 2018 11:43 Go to next message
my grammar looks like:
Eq:
	'eq' value=STRING | NUMBER |NULL;
NUMBER:
	'-'? INT ('.' INT)?;
terminal NULL:
	'null';
Currently the interface Eq constains a method `String getValue`, how can i change this to`Object getValue`?
[Updated on: Fri, 05 January 2018 12:32] by Moderator
Re: Use object as type instead of String [message #1779359 is a reply to message #1779350] Fri, 05 January 2018 12:25 Go to previous messageGo to next message
can you please give some more context. if (at all) the type would be EObject? or do you mean java.lang.Object? if yes what do you want to fill it with?
Re: Use object as type instead of String [message #1779361 is a reply to message #1779359] Fri, 05 January 2018 12:38 Go to previous messageGo to next message
The EObject is ok as well.
Currently the value is always a String (at the modell class), but it can be null or 112 or 11.2. or "A".
The issue is I do not know the original value anymore.
Small example with null:
	@Test
	public void parseNull() {
		final String value = null;
		String expression = "eq"+ value;
                //parsing...
		Eq eq;
		assertThat(eq.getValue()).isEqualTo(value);
JUnit result said: Expected null Actual: "null"
Thanks for your help
[Updated on: Fri, 05 January 2018 12:39] by Moderator
Re: Use object as type instead of String [message #1779367 is a reply to message #1779361] Fri, 05 January 2018 12:51 Go to previous messageGo to next message
that sounds like a parse error?!?
the question is your semantic?
wouldnt it be better to have a StringLiteral, a NumberLiteral, and Null as separate types?
Re: Use object as type instead of String [message #1779371 is a reply to message #1779367] Fri, 05 January 2018 13:06 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 17:51
Why should this be a parse error?
The semantic is like:
eq(attribute, "a") or eq(attribute, 1) or eq(attribute, null)
Do you mean something like this:
Instead of
Eq:
	'eq' '(' attribute=FIELD_VALUE ',' value=STRING | INT | NULL')';
this:
Eq:
	EqString | EqInt ...
EqString:
	'eq' '(' attribute=FIELD_VALUE ',' value=STRING')';
EqInt:
       'eq' '(' attribute=FIELD_VALUE ',' value=INT')';
Re: Use object as type instead of String [message #1779372 is a reply to message #1779367] Fri, 05 January 2018 13:07 Go to previous messageGo to next message
Instead of
Eq:
this:
Eq:
EqString:
EqInt:
Re: Use object as type instead of String [message #1779373 is a reply to message #1779367] Fri, 05 January 2018 13:07 Go to previous messageGo to next message
Instead of
Eq:
this:
Eq:
EqString:
EqInt:
Re: Use object as type instead of String [message #1779374 is a reply to message #1779373] Fri, 05 January 2018 13:08 Go to previous messageGo to next message
so eq is (field, value) ?
Re: Use object as type instead of String [message #1779375 is a reply to message #1779367] Fri, 05 January 2018 13:08 Go to previous messageGo to next message
Instead of
Eq:
this:
Eq:
EqString:
EqInt:
Re: Use object as type instead of String [message #1779376 is a reply to message #1779375] Fri, 05 January 2018 13:11 Go to previous messageGo to next message
i mean something like
value=ValueExpression
ValueExpression: StringLiteral | IntLiteral | NullLiteral;
StringLiteral: value=STRING
IntLiteral: value=INT
NullLiteral: {NullLiteral} "NULL";
Re: Use object as type instead of String [message #1779377 is a reply to message #1779376] Fri, 05 January 2018 13:23 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 18:11
I have already done that, I have abbreviated this only for the example.
Sorry for the confusion:
This are my type rules
Eq:
	'eq' '(' attribute=FIELD_VALUE ',' value=Literal ')';
Literal:
	(StringOrNumberLiteral | BOOLEAN | NULL);
StringOrNumberLiteral:
	STRING | NUMBER;
NUMBER:
terminal BOOLEAN returns ecore::EBoolean:
	'true' | 'false';
terminal NULL:
	'null';
terminal FIELD_VALUE:
	('A'..'Z' | 'a'..'z') ('A'..'Z' | 'a'..'z' | '0'..'9' | '.' | '_' | '-')*;
Re: Use object as type instead of String [message #1779378 is a reply to message #1779377] Fri, 05 January 2018 13:37 Go to previous messageGo to next message
And Whats your actual question
Re: Use object as type instead of String [message #1779390 is a reply to message #1779378] Fri, 05 January 2018 17:08 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 18:37
The question is why looks the Eq like this
class Eq
String getValue()
insteadOf
class Eq
EObject getValue()
I have the same issue for the In operator
class In
List<Strings> getValues()
How should i validate the datatype, if all values are strings?
How can I check if it was a 1 or "1"
Re: Use object as type instead of String [message #1779393 is a reply to message #1779390] Fri, 05 January 2018 17:46 Go to previous messageGo to next message
As I said. Make the literals eobjects
By using assignments
Then you can instanceof
Re: Use object as type instead of String [message #1779399 is a reply to message #1779393] Sat, 06 January 2018 05:23 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 22:46
Ahh sorry didn't see the assignments. I will try that.
Edit: Works :)
[Updated on: Mon, 08 January 2018 01:57] by Moderator
Re: Use object as type instead of String [message #1779458 is a reply to message #1779359] Mon, 08 January 2018 05:18 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 17:25
1 more question, sorry. Now the value of Literal(s) are EObjects. Is it possible to replace it with java.lang.Object?
Model code:
 EObject getValue();
Re: Use object as type instead of String [message #1779461 is a reply to message #1779458] Mon, 08 January 2018 05:23 Go to previous messageGo to next message
why do you want to?
Re: Use object as type instead of String [message #1779462 is a reply to message #1779461] Mon, 08 January 2018 05:24 Go to previous messageGo to next message
and how does the grammar look like. maybe you did something wrong
Re: Use object as type instead of String [message #1779466 is a reply to message #1779461] Mon, 08 January 2018 05:39 Go to previous messageGo to next message
Christian Dietrich wrote on Mon, 08 January 2018 10:23
why do you want to?
Because a EObject is a interface and a Object is easier to use:
This will not compile if the list contains EObjects
assertThat(inFilter.getValues()).contains("a", "b");
I found this solution, but this no good idea, becuase the conversion is not working anymore
Literal returns ecore::EJavaObject:
	StringOrNumberLiteral | BOOLEAN | NULL;
StringOrNumberLiteral returns ecore::EJavaObject:
	(STRING | NUMBER);
[Updated on: Mon, 08 January 2018 06:58] by Moderator
Re: Use object as type instead of String [message #1779472 is a reply to message #1779462] Mon, 08 January 2018 07:17 Go to previous messageGo to next message
Christian Dietrich wrote on Mon, 08 January 2018 10:24
Currently looks like, but iam not happy with it.
That's way too many classes. That's why an object would be my favorite. Is that not possible?
Literal returns ecore::EObject:
	(StringOrNumberLiteral | BooleanValue | NullValue);
StringOrNumberLiteral returns ecore::EObject:
	(StringLiteral | NumberValue);
StringLiteral returns ecore::EObject:
	StringValue;
StringValue:
	value = STRING;
NumberValue:
	value = DOUBLE;
BooleanValue:
	value = BOOLEAN;
NullValue:
	value = NULL;
[Updated on: Mon, 08 January 2018 07:35] by Moderator
Re: Use object as type instead of String [message #1779475 is a reply to message #1779472] Mon, 08 January 2018 07:48 Go to previous messageGo to next message
no i meant
Literal:
StringLiteral:
value = STRING;
NumberValue:
value = DOUBLE;
BooleanValue:
value = BOOLEAN;
NullValue:
value = NULL;
Re: Use object as type instead of String [message #1779477 is a reply to message #1779475] Mon, 08 January 2018 07:54 Go to previous messageGo to next message
Yes but then i have a Literal Class and a lot of sub classes.
Is that unavoidable?
i would prefer something like
value=(STRING | INT)
Object getValue()
[Updated on: Mon, 08 January 2018 08:00] by Moderator
Re: Use object as type instead of String [message #1779480 is a reply to message #1779477] Mon, 08 January 2018 08:10 Go to previous messageGo to next message
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=WhyTypesIfYouCanHaveObject '!';
// TODO implement value converter
WhyTypesIfYouCanHaveObject returns ecore::EJavaObject:
INT | STRING
Re: Use object as type instead of String [message #1779481 is a reply to message #1779480] Mon, 08 January 2018 08:19 Go to previous messageGo to next message
Okay understand will try to solve it better with types.
Re: Use object as type instead of String [message #1779482 is a reply to message #1779475] Mon, 08 January 2018 09:00 Go to previous message
Christian Dietrich wrote on Mon, 08 January 2018 12:48
no i meant
Literal:
StringLiteral:
value = STRING;
NumberValue:
value = DOUBLE;
BooleanValue:
value = BOOLEAN;
NullValue:
value = NULL;
Mhm ok this works, but with this solution i have a lots of cast, because the Literal class has no getValue(). Just the subclasses has a getValue
		StringLiteral literal = (StringLiteral) eq.getLiteral();
		assertThat(literal.getValue()).isEqualTo("4711");
Previous Topic:Unit Test with @Traced
Next Topic:Deploying xtext features
Current Time: Thu Jul 24 23:26:28 EDT 2025
Powered by FUDForum. Page generated in 0.11696 seconds
