Home » Modeling » GMF (Graphical Modeling Framework) » multi-line text editor for label editing
multi-line text editor for label editing [message #177769] Tue, 18 March 2008 01:24 Go to next message
Originally posted by: zhihui_yang73.yahoo.com
Hi all,
i need an editpart which is similar as the one used for Note. For now, I
can get the Note shape using NoteFigure. I also use a WrappingLabel to
capture the description of the node. My node wraps the label according to
the size of the figure nicely. However, I can only edit the label content
in a single line text editor, which is not the same as the text editor
used by Note. Can anybody please tell me how I can use multi-line text
editor within my node as what Note does?
Thanks a lot!
Re: multi-line text editor for label editing [message #177935 is a reply to message #177769] Tue, 18 March 2008 13:35 Go to previous messageGo to next message
Originally posted by: jan.koehnlein.web.de
Spot the WrapLabel in the figure of the edit part, and set
setTextWrap(true)
ZYang wrote:
> Hi all,
> to the size of the figure nicely. However, I can only edit the label
> content in a single line text editor, which is not the same as the text
> editor used by Note. Can anybody please tell me how I can use multi-line
> text editor within my node as what Note does?
> Thanks a lot!
Re: multi-line text editor for label editing [message #177958 is a reply to message #177935] Tue, 18 March 2008 15:22 Go to previous messageGo to next message
Hey Jan,
I did set text wrap to true using setTextWrap(true). It wraps my label
nicely according to the size of my node. My problem is that when I try to
edit the label, instead of let me edit the label directly; it shows a
single line text editor on top of the label. I can only edit the content
of my label using that single line text editor. I can see the label
content changed accordingly under the text editor. Once I'm done with the
editing, and click somewhere in the diagram, the text editor will
disappear. It is very annoying and hard to edit when the content of the
label is long. Is there anywhere else I should change in order to edit the
wrapped label directly with a multi-line text editor?
BTW, I am using WrappingLabel with the latest GMF build 2.1M5
Thanks.
Re: multi-line text editor for label editing [message #177990 is a reply to message #177958] Tue, 18 March 2008 15:47 Go to previous messageGo to next message
The problem was solved after I replaced WrappingLabel with old WrapLabel.
But still not sure why WrappingLabel works strangely in my case.
Re: multi-line text editor for label editing [message #178218 is a reply to message #177958] Wed, 19 March 2008 16:18 Go to previous message
This seems odd. Check which DirectEditManager is being used when
editing the label, by putting a breakpoint in the label's editpart's
performDirectEdit() methods. If your editpart is a subclass to
TextCompartmentEditPart it should be using the TextDirectEditManager
which should show multi-line text.
Cherie
ZYang wrote:
> Hey Jan,
> to edit the label, instead of let me edit the label directly; it shows a
> the editing, and click somewhere in the diagram, the text editor will
> the wrapped label directly with a multi-line text editor?
> Thanks.
Previous Topic:please help me GMF
Next Topic:Query With method.(createFigure)
Current Time: Fri Jul 18 18:32:27 EDT 2025
Powered by FUDForum. Page generated in 0.04365 seconds
