Home » Modeling » TMF (Xtext) » Consistent Datatype for values
Consistent Datatype for values [message #1779336] Fri, 05 January 2018 09:47 Go to next message
I would like to check for an "in" operator, that always consistent data types are included in the values:
e.g.
only Strings
in(attr,("A","B")
only numbers
in(attr,1,2.0)
The xtext grammar:
In:
	'in' '(' attribute=FIELD_VALUE ',' '(' values+=Literal (',' values+=Literal)* ')' ')';
Can I do that directly in the grammar?
Re: Consistent Datatype for values [message #1779337 is a reply to message #1779336] Fri, 05 January 2018 10:03 Go to previous messageGo to next message
You can but your users won't thank you. Every typo will be a syntax error. If instead you have a semantic validation, you can provide a much more informative warning and maybe even a quick fix. Subsequent maintainers won't thank you either since your grammar will have excessive complexity.
Ed Willink
Re: Consistent Datatype for values [message #1779347 is a reply to message #1779337] Fri, 05 January 2018 11:34 Go to previous messageGo to next message
thanks for the quick answer.
But i have no UI, so the User cannot use a quickfix ;).
Re: Consistent Datatype for values [message #1779360 is a reply to message #1779347] Fri, 05 January 2018 12:27 Go to previous messageGo to next message
well even then a simple validation with an error message like: "please use the same type" would be better than "parse error"
never do such things in the grammar
Re: Consistent Datatype for values [message #1779363 is a reply to message #1779360] Fri, 05 January 2018 12:44 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 17:27
Okay thanks. Then i will do that in AbstractValidator, or?
[Updated on: Fri, 05 January 2018 12:47] by Moderator
Re: Consistent Datatype for values [message #1779364 is a reply to message #1779363] Fri, 05 January 2018 12:45 Go to previous messageGo to next message
you have already a MyDslValidator pregenerated. yes
Re: Consistent Datatype for values [message #1779365 is a reply to message #1779364] Fri, 05 January 2018 12:48 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 January 2018 17:45
Okay thanks :)
Antoher related question. A attribute (like in Java) should always start with a character. My solution is:
terminal FIELD_VALUE:
	('A'..'Z' | 'a'..'z') ('A'..'Z' | 'a'..'z' | '0'..'9' | '.' | '_' | '-')*;
Is this ok? Or should i create a validation as well?
[Updated on: Fri, 05 January 2018 12:51] by Moderator
Re: Consistent Datatype for values [message #1779366 is a reply to message #1779365] Fri, 05 January 2018 12:50 Go to previous messageGo to next message
that's ok, depends on other places you use similar IDs.
Re: Consistent Datatype for values [message #1779368 is a reply to message #1779366] Fri, 05 January 2018 12:52 Go to previous message
Christian Dietrich wrote on Fri, 05 January 2018 17:50
Okay, then i will try to create a validation
EDIT: okay now i have the same issue like in my other thread all values are strings ;). So i cannot check the data type. First i have to fix this, before i can create a validation
[Updated on: Fri, 05 January 2018 13:08] by Moderator
Previous Topic:Connecting to a non-xtext language from Eclipse: Binding ResourceDescriptionStrategy
Next Topic:BIRT Pie Chart
Current Time: Wed Jul 23 10:47:49 EDT 2025
Powered by FUDForum. Page generated in 0.08803 seconds
