Quickfix NullPointerException in PartialSerializer [message #1779172] |
Wed, 03 January 2018 08:51  |
I'm having problems in Xtext 2.13 with quickfixes that i didn't have in 2.12, i suppose related to the changes applied to support multiple quickfix resolutions.
The problem appears when a node A is added to the AST tree and then another node is added as a child of A
at org.eclipse.xtext.ide.serializer.impl.PartialSerializer$SerializeRecursiveStrategy.serialize(PartialSerializer.java:155)
at org.eclipse.xtext.ide.serializer.impl.PartialSerializer.serializeChanges(PartialSerializer.java:280)
at org.eclipse.xtext.ide.serializer.impl.RecordingXtextResourceUpdater.applyChange(RecordingXtextResourceUpdater.java:80)
at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.endRecordChanges(ChangeSerializer.java:162)
at org.eclipse.xtext.ide.serializer.impl.ChangeSerializer.applyModifications(ChangeSerializer.java:93)
at org.eclipse.xtext.ui.editor.model.edit.BatchModification.applyInWorkspace(BatchModification.java:142)
The problem happens with a single quickfix, but it can be avoided somehow waiting to add the node A until it's fully set.
The problem is much more difficult to solve if several quickfixes are applied together and the business rules are complex
As an example, i've made a simple test case
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
classes+=Class* statements+=Statement+;
Class:
'class' name=ID '{' vars+=Variable+ '}';
Variable: name=ID;
Statement: var=[Variable|VariableQN] '=' INT;
VariableQN hidden(): ID '.' ID;
@Fix(Diagnostic.LINKING_DIAGNOSTIC)
def void fixMissingEntity(Issue issue, IssueResolutionAcceptor acceptor) {
if (issue.message.contains("Variable")) {
fixMissingVariable(issue, acceptor);
private def fixMissingVariable(Issue issue, IssueResolutionAcceptor acceptor) {
acceptor.acceptMulti(
issue,
"Create missing variable definition",
"Entity.gif",
[ Statement element, ICompositeModificationContext<Statement> context |
val fullReferenceName = getIssueMissingReferenceName(context.issue)
val nameArray = fullReferenceName.split("\\.")
val className = nameArray.get(0)
val fieldName = nameArray.get(1)
val root = element.eContainer as Model
context.addModification(root, [ctx |
var cl = root.classes.findFirst[it.name == className]
if (cl === null) {
// The class didn't exist
cl = MyDslFactory::eINSTANCE.createClass() => [
name = className
// before adding the class, we can add the field
addVariable(cl, fieldName)
ctx.classes.add(cl)
// after adding the class, adding the field will cause NullPointerException in Serialization
// addVariable(cl, fieldName)
} else {
// The class existed (maybe created in a previous multiquickfix)
// NullPointerException if 2 fixs are applied together and the parent class was added in the first fix
protected def boolean addVariable(Class cl, String fieldName) {
val atr = MyDslFactory::eINSTANCE.createVariable() => [
name = fieldName
cl.vars.add(atr)
private def String getIssueMissingReferenceName(Issue issue) {
// Not the best way ...
val issueMessage = issue.message
val j = issueMessage.lastIndexOf("'")
val i = issueMessage.lastIndexOf("'", j - 1)
issueMessage.substring(i+1, j)
Example code:
// aplying the fix to this 2 problems together works because they create their own classes
Class1.test1 = 1
Class2.test2 = 1
// aplying the fix to this 2 problems together don't work because the first adds the class plus field and the second adds another field to the new class
Class3.test3 = 1
Class3.test4 = 1
Re: Quickfix NullPointerException in PartialSerializer [message #1779226 is a reply to message #1779192] |
Thu, 04 January 2018 03:06  |
https://github.com/eclipse/xtext-core/issues/597
I have a grammar used with legacy code and clients always send code with missing parts, so it's very useful to be able to apply massive quickfixes.
I kind of implemented a menu option to apply single quickfixes one after another project-wide (only aplied to a few specific custom quickfixes) and it worked pretty well in 2.12
After changing to 2.13, the output of the multiple single-quickfixes was corrupted, so i changed it to multiquickfixes and then i faced with the nullPointers
As a side question, if a quickfix has to modify a referenced resource (for example, add a field to a class in other source file), can it be done as if it were in the same source file or it needs additional steps?
FUDForum. Page generated in 0.08382 seconds
