Home » Modeling » TMF (Xtext) » How to parse a normal text file for unit test
How to parse a normal text file for unit test [message #1779146] Wed, 03 January 2018 04:01 Go to next message
I am writing some unit test, So I want to parse the xtext file to generate some xml , basically I want to parse the file as model in unit test and use it to generate its corresponding xml?
Re: How to parse a normal text file for unit test [message #1779190 is a reply to message #1779146] Wed, 03 January 2018 12:16 Go to previous messageGo to next message
hi,
what exactly is your problem?
Re: How to parse a normal text file for unit test [message #1779191 is a reply to message #1779146] Wed, 03 January 2018 12:18 Go to previous messageGo to next message
This happens automatically, if you just use the normal standard EMF ResourceSet.getResource API
GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.xtext2lpg\src\org\eclipse\ocl\examples\xtext2lpg\xtext2xbnf.qvto
shiows that a *.xtext file can be the input for a QVTo transformation (again just exploiting Xtext's nice automatic parsing from grammar-defined source to equivalent token model).
Ed Willink
Re: How to parse a normal text file for unit test [message #1779234 is a reply to message #1779190] Thu, 04 January 2018 04:13 Go to previous messageGo to next message
I want to know how to parse a XXXX.myExtension file in my unit test which should generate some xml file correspond to XXXX.myExtension file .
Note: xxxx.myExtension in somewhere in some different package in same project
Re: How to parse a normal text file for unit test [message #1779242 is a reply to message #1779234] Thu, 04 January 2018 05:21 Go to previous messageGo to next message
there are may factors on how you run your unit test etc. you give zero context so its just wild wild guessing what fits for you
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
	@Inject
	Provider<ResourceSet> rsp
	@Test
	def void loadModel() {
		val rs = rsp.get
		// better use a file uri, but your question lacks context
		val r = rs.getResource(URI.createURI("classpath:/org/xtext/example/other/other.mydsl"), true)
		r.load(null)
		val model = r.contents.head as Model
		for (g : model.greetings) {
			println(g.name)
Re: How to parse a normal text file for unit test [message #1779243 is a reply to message #1779242] Thu, 04 January 2018 05:26 Go to previous message
or with some generator calling
	@Inject
	@Inject
	GeneratorDelegate generatorDelegate
	@Test
		val rs = rsp.get
		r.load(null)
			println(g.name)
		val GeneratorContext context = new GeneratorContext();
		context.setCancelIndicator(CancelIndicator.NullImpl);
		val fsa = new InMemoryFileSystemAccess
		generatorDelegate.doGenerate(r,fsa,context)
		println(fsa.allFiles)
Previous Topic:Quickfix NullPointerException in PartialSerializer
Next Topic:Connecting to a non-xtext language from Eclipse: Binding ResourceDescriptionStrategy
Current Time: Fri Jul 25 00:00:08 EDT 2025
Powered by FUDForum. Page generated in 0.14659 seconds
