Re: Part's persisted state is lost even with apply="notexists" [message #1779235 is a reply to message #1779178] |
Thu, 04 January 2018 04:19  |
I forgot to mention this is with Eclipse 4.6.
Debugging shows that in org.eclipse.e4.ui.internal.workbench.ModelAssembler the elements of the restored application model are overwritten with the corresponding elements from the fragment even if apply="notexists" is set.
Here comes the method processModelFragment():
* Contributes the given {@link MModelFragment} to the application model.
* @param fragment
* the fragment to add to the application model
* @param contributorURI
* the URI of the element that contributes this fragment
* @param checkExist
* specifies whether we should check that the application model
* doesn't already contain the elements contributed by the
* fragment before merging them
* @return a list of the {@link MApplicationElement} elements that were
* merged into the application model by the fragment
public List<MApplicationElement> processModelFragment(MModelFragment fragment, String contributorURI,
boolean checkExist) {
E4XMIResource applicationResource = (E4XMIResource) ((EObject) application).eResource();
List<MApplicationElement> elements = fragment.getElements();
if (elements.size() == 0) {
return new ArrayList<>();
for (MApplicationElement el : elements) {
EObject o = (EObject) el;
E4XMIResource r = (E4XMIResource) o.eResource();
if (checkExist && applicationResource.getIDToEObjectMap().containsKey(r.getID(o))) {
continue;
applicationResource.setID(o, r.getID(o));
if (contributorURI != null)
el.setContributorURI(contributorURI);
// Remember IDs of subitems
TreeIterator<EObject> treeIt = EcoreUtil.getAllContents(o, true);
while (treeIt.hasNext()) {
EObject eObj = treeIt.next();
r = (E4XMIResource) eObj.eResource();
if (contributorURI != null && (eObj instanceof MApplicationElement))
((MApplicationElement) eObj).setContributorURI(contributorURI);
applicationResource.setID(eObj, r.getInternalId(eObj));
return fragment.merge(application); // <=== here the fragment gets unconditionally merged into the app model !
The flag checkExist is true if the fragment property apply="notexists". The mere effect of this is that the object ids in the application model are not overwritten with object ids from the fragment. But in the last line of this method the fragment is unconditionally merged into the application model, thereby wiping the persisted state of the part.
The conclusion for me is that the flag apply="notexists" only takes care that a part keeps its visual position in the workbench and is not duplicated (e.g. when the user moves it to a different PartStack) but still the part itself is replaced with the part from the fragment.
The consequence is that the persistedState is lost.
Is this intended behaviour and I am misunderstanding something here? Or should I raise a bug report?
Cheers, Wernke
[Updated on: Thu, 04 January 2018 07:43] by Moderator
FUDForum. Page generated in 0.05470 seconds
