Dynamic Master Page footer based on XML data field [message #1621290] |
Tue, 17 February 2015 15:19  |
Hello all,
My problem is that I have a Header, repeating accounting lines grouped by a Vendor, and a Footer and both the Header and Footer must have a fixed position on the page and display data associated with that Vendor, which changes throughout. I would like for any overflow of the accounting lines to be pushed to the next page naturally without using the Intervals setting on the Group.
So, my solution is to place the Footer on the Master Page and use Global Variables to change the data to the current XML data that is being used by the Group. I have already tried to bind the grid on the Master Page to XML, but it only displays the first Vendor's information.
Will variables fix this, or is there another solution?
Edit: Here are the files. I am currently using an Interval Range of 2 and I for either the Interval Range to change once we get to the second page of the Vendor (keep in mind there will be multiple Vendors), or to have the Footer placed in the Master Page (so that excessive accounting lines don't push it off the first page) and have the data in the Footer still change depending on the Vendor
Keegan
[Updated on: Wed, 18 February 2015 12:25] by Moderator
Re: Dynamic Master Page footer based on XML data field [message #1779103 is a reply to message #1633449] |
Tue, 02 January 2018 15:35  |
Hi -
I'm looking to add an employee ID field to the master page footer of my report. I looked at the file attached as an example. I'm running into an issue with the first page footer isn't returning a value. Then the second page returns the employee id from the first page. When I run the attached report is see the same behavior. Did you find a solution to this?
Thank you!
FUDForum. Page generated in 0.06543 seconds
