Home » Eclipse Projects » Sirius » programmatic access to the Sirius model via the EMF API(I am not sure how the Java clients able to traverse the models created from the Eclipse Modeling Project or created from a Sirius diagram should be created)
programmatic access to the Sirius model via the EMF API [message #1779038] Fri, 29 December 2017 11:26 Go to next message
I am following the Sirius tutorials. And my questions regarding this one
https://wiki.eclipse.org/Sirius/Tutorials/DomainModelTutorial
and this one:
https://wiki.eclipse.org/Sirius/Tutorials/StarterTutorial
are:
- what should I do after finishing "Create a new Modeling Project" section of the first one to be able to traverse the eCore model programmatically through the EMF API (perhaps via ECoreUtil.getRootContainer() method to get acces to the root model object) [what kind of the Eclipse project, how created - from which Eclipse instance, how executed,...]?
- are the steps exactly the same in the case of creating the model from the Sirius diagram or the Sirius must be used as a proxy for accessing the model in such the case?
Thank you in advance for the answers.
Re: programmatic access to the Sirius model via the EMF API [message #1779078 is a reply to message #1779038] Tue, 02 January 2018 04:19 Go to previous messageGo to next message
If you want to know more about how to use EMF API I highly suggest you reading http://www.informit.com/store/emf-eclipse-modeling-framework-9780321331885
If you want support about how to use the API, the EMF Eclipse forum is more appropriate.
In short, one very simple way to access your own ecore metamodel:
File file = new File(pathToMyEcoreFile);
ResourceSet rs = new ResourceSetImpl();
		rs.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE );
		Registry r = rs.getResourceFactoryRegistry();
		Map<String,Object> m = r.getExtensionToFactoryMap();
		m.put("ecore",new XMIResourceFactoryImpl());
		URI uri = URI.createFileURI(file.getAbsolutePath());
		Resource resource = rs.getResource(uri, true);
The resource contains your metamodel.
The root element is accessible with resource.getContents()
Call this code from a java class in an Eclipse plug-in declaring as dependency the plugin with your metamodel and emf.ecore plugins. Your metamodel plugin can be in the same eclipse instance than your calling plugin.
It works exactly the same with Sirius <.aird> models created with Sirius editors.
You just have to use the right package and extension name.
Though you have some helpers in Sirius allowing to load the session represented by the .aird file.
In your plugin loading models you must add a dependency to org.eclipse.sirius to use it:
Session session = SessionManager.INSTANCE.getSession(airdFileUri, new NullProgressMonitor());
In pure Sirius your session will be a DAnalysisSessionImpl so you can cast it as such to be able to extract contents from EMF API.
[Updated on: Tue, 02 January 2018 04:48] by Moderator
Re: programmatic access to the Sirius model via the EMF API [message #1779210 is a reply to message #1779078] Wed, 03 January 2018 16:01 Go to previous messageGo to next message
Thank you for your great and quick answer.
My question was however connected to accessing not the eCore metamodel (domain-specific modeling language definition) but the model (the instance of the DSML defined in the form of the diagram with notation defined in Sirius in the form of the eCore model) created in Sirius. I am interested in accessing the model and not the diagram. Sorry if my question was too laconic.
Should I ask the question directly on EMF forum or there are some Sirius-specific issues you may help me to identify before?
Re: programmatic access to the Sirius model via the EMF API [message #1779260 is a reply to message #1779210] Thu, 04 January 2018 09:52 Go to previous messageGo to next message
Sorry for the misunderstanding,
Ecore is a metamodel and .ecore files contains the instance models. So to access your models instances it works the same. Just replace what is relative to Ecore metamodel by yours and point at your model instance file. For example with a metamodel producing model instance file with extension "myextension" (file.myextension)
		rs.getPackageRegistry().put([b]MyCustomMetamodelPackage[/b].eNS_URI, [b]MyCustomMetamodelPackage[/b].eINSTANCE );
		m.put("[b]myextension[/b]",new XMIResourceFactoryImpl());
For the Sirius part, the Sirius model instances from Sirius metamodels are the .aird files in your modeling projects. They contains graphical representation information of your models. But Sirius uses EMF API to create, access and modify your model. There is nothing specific to Sirius regarding your models.
In conclusion, the first solution with some adaptation specific to your metamodel allows you to read your models from EMF API independently from Sirius.
The second one give you the Sirius object representing the Sirius model instance (Session) containing graphical information and referencing used models of yours as semantic resources. So you can also access your models from the Sirius one with the Session API getSemanticResources() method.
Re: programmatic access to the Sirius model via the EMF API [message #1779732 is a reply to message #1779260] Thu, 11 January 2018 16:38 Go to previous message
Hi Pierre,
your explanation was very useful and your solution works perfectly. Thank you so much :)
Previous Topic:Hide a password attribute content
Next Topic:Question about advanced configuration in Sirius
Current Time: Mon Jul 21 14:56:42 EDT 2025
Powered by FUDForum. Page generated in 0.05008 seconds
