Home » Newcomers » Newcomers » improvements to the debugger
improvements to the debugger [message #177791] Wed, 01 November 2006 07:54 Go to next message
Originally posted by: giraffiti101.yahoo.com
Hi all,
Are there any planes to improve the debugging functions in Eclipse?
I'm missing some nice features that were in Visual c++.
For instance showing the return values from functions in the variables
window.
For example if you are stepping over this line, you there is no easy way
to check the return value of calcValue():
int x = var1 * calcValue()/1000;
public int calcValue()
return Math.sqrt(member)*1.222;
you end up writing an extra line of code, just to see the return value:
int x = Math.sqrt(member)*1.222;
return x;
Re: improvements to the debugger [message #177818 is a reply to message #177791] Wed, 01 November 2006 08:57 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Ed wrote:
> Hi all,
> Are there any planes to improve the debugging functions in Eclipse? I'm
> missing some nice features that were in Visual c++. For instance showing
> the return values from functions in the variables window. For example if
> you are stepping over this line, you there is no easy way to check the
> return x;
Hi Ed. Try asking this question in eclipse.tools.cdt (C/C++ Development
Tools). You might also consider taking a look in Bugzilla to see if
there are any plans.
Wayne
Re: improvements to the debugger [message #177852 is a reply to message #177818] Wed, 01 November 2006 09:47 Go to previous messageGo to next message
Does eclipse.tools.cdt have a web interface like this one?
Unfortunately I am not able to post in news groups
Re: improvements to the debugger [message #177859 is a reply to message #177852] Wed, 01 November 2006 11:03 Go to previous messageGo to next message
It should. It's on the same server as this newsgroup.
Wayne
Re: improvements to the debugger [message #177895 is a reply to message #177791] Wed, 01 November 2006 12:17 Go to previous messageGo to next message
Originally posted by: eclipse4.rizzoweb.com
Ed wrote:
> Hi all,
I know they are working on this feature for Java (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75519). You may want to
post a similar feature request under the CDT product.
Hope this helps,
Eric
Re: improvements to the debugger [message #177903 is a reply to message #177895] Wed, 01 November 2006 12:43 Go to previous message
Yeah, I see now that many people have had the same wish, but seems to be
some problem in the java debugger that doesn't allow them to implement it.
Previous Topic:Update Manager
Next Topic:separate product and feature projects?
Current Time: Mon Nov 03 03:46:17 EST 2025
Powered by FUDForum. Page generated in 0.10596 seconds
