Home » Eclipse Projects » Sirius » Sirius + EEF - the simplest way to customize property behaviour
Sirius + EEF - the simplest way to customize property behaviour [message #1778796] Thu, 21 December 2017 09:41 Go to next message
I have a question connected with a property customisation when using Sirius + EEF. I have a property that is needed to appear only when it is connected with specific type of input block. So I need an eObject and depending on it the property(its control) has to be hiden or not. I have investigated this guide: https://wiki.eclipse.org/EEF/User_Guide/Custom_Element_Editor
But isn't it a very difficult way? Isn't it possible to inject it in some proper place without regeneration of my field as custom (I already have it in my model, why)?
Thank you.
Pavel
Re: Sirius + EEF - the simplest way to customize property behaviour [message #1778800 is a reply to message #1778796] Thu, 21 December 2017 10:21 Go to previous messageGo to next message
The documentation you point to correspond to the old version of EEF (up to version 1.5), which relied on static code generation. If indeed you're using this version, note that it is deprecated (it still works, but is not actively developed anymore). I'm no expert on that older version but I'm afraid there's no probably no other way that the one documented there.
The new version of EEF (currently at 2.0) is a completely new code base which uses a more Sirius-like approach with no code generation at all. It has actually been designed specifically to integrate well with Sirius (although it can also be used separately) and is the recommended version to use for new developments. You can find more documentation about how to use it in Sirius at https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html. The specific problem you mention about showing a property or not depending on the model state is directly supported, for example by specifying an appropriate Precondition Expression on your widget.
Re: Sirius + EEF - the simplest way to customize property behaviour [message #1778827 is a reply to message #1778800] Fri, 22 December 2017 04:06 Go to previous messageGo to next message
Hello, Pierre-Charles David
I am restricted of using 1.5 version of EEF.
Are you talking about changes in *.odesign? Or I have to create my custom widget? If I use standart widget, do I have any possibility to create Precondition Expression for it?
Thank you for your answer.
Pavel
Re: Sirius + EEF - the simplest way to customize property behaviour [message #1778831 is a reply to message #1778827] Fri, 22 December 2017 05:13 Go to previous messageGo to next message
Pavel Bogdanov wrote on Fri, 22 December 2017 10:06
EEF 1.5 is completely independent on Sirius and is not configured through the odesign files. Configuration from these files and the "Precondition Expression" I mentioned are only available in EEF 2.0. If you're stuck with 1.5, I'm afraid regenerating may be the only way to handle your requirement.
Re: Sirius + EEF - the simplest way to customize property behaviour [message #1778834 is a reply to message #1778831] Fri, 22 December 2017 05:37 Go to previous message
Ok, I see I do it right way.
Thank you.
Pavel
Previous Topic:References are lost when Copy elements from project to project
Next Topic:Duplication memory in Sirius, GMF or EMF?
Current Time: Sun Jul 27 09:34:09 EDT 2025
Powered by FUDForum. Page generated in 0.04009 seconds
