Home » Eclipse Projects » Kura » Problem, creating new Wire Asset
Problem, creating new Wire Asset [message #1778731] Wed, 20 December 2017 09:12 Go to next message
Hi guys,
I tried to develop a new Asset (I extended BaseAsset and implement WireEmitter and WireReceiver), but when I started kura, it always refers at the its normal asset.
I don't understand..
can someone help me?
below you will also find the code implemented by me
Re: Problem, creating new Wire Asset [message #1778740 is a reply to message #1778731] Wed, 20 December 2017 10:58 Go to previous messageGo to next message
I'll try to have a look at your code.
Can I ask you why you need to develop a new Asset? In theory the asset is an abstraction over the drivers, so there should be no need to develop another implementation site most of the information related to a channel is provided by the drivers.
Thanks.
Matteo
Re: Problem, creating new Wire Asset [message #1778743 is a reply to message #1778740] Wed, 20 December 2017 11:39 Go to previous message
Thanks so much!
I'm doing it just to see the internal mechanisms and as if to change them at my leisure
Stefano
Previous Topic:persistance in kura
Next Topic:build and deploy Kura using docker
Current Time: Wed Jul 30 23:07:46 EDT 2025
Powered by FUDForum. Page generated in 0.03806 seconds
