Home » Language IDEs » C / C++ IDE (CDT) » Help me!(An error has occured...)
Help me! [message #1778553] Sun, 17 December 2017 02:39 Go to next message
For a long time I've been looking for a lightweight IDE for C++, and Eclipse CDT seemed to be the right thing. I was excited to finally get back into C++ (I stopped because school and homework exist.) but when I try to create a new C++ project, it gives me an error: "Cannot run program 'gcc': Launching Failed". How do I fix this?
Re: Help me! [message #1778684 is a reply to message #1778553] Tue, 19 December 2017 23:05 Go to previous message
There is a lot of confusion among beginners as to what Eclipse actually does.
It is primarily a text editor which can call external programs to build and debug projects.
It defaults to building using GNU Make directly or emulated.
It can create the makefile used by Make or use one provided by the user.
In addition to needing Make, Eclipse also needs a compiler and a linker.
It will create Make recipes which call the compiler and linker.
The default is to use GCC to provide these but, of course, others can be used.
This means you must have GCC and Make installed on your system.
They are not provided by Eclipse.
You need to read all of: http://help.eclipse.org/oxygen/index.jsp?topic=%2Forg.eclipse.cdt.doc.user%2Fconcepts%2Fcdt_o_home.htm
Particularly, Before you Begin and Getting Started.
Previous Topic:how to install zoil ineclipse c++ neon
Next Topic:"Launch failed. Binary not found."
Current Time: Sun Jul 27 02:29:27 EDT 2025
Powered by FUDForum. Page generated in 0.05038 seconds
