Home » Archived » BIRT » Strange exception
Strange exception [message #122993] Thu, 02 February 2006 06:48 Go to next message
Originally posted by: r.budner.abg.com.pl
Hi.
Let's assume that we have two data sets and two tables. Each table is
bound to its corresponding data set. First table is a master table and
the second is a subreport (inner) table. The two data sets are
additionaly linked together (join). So, for each record in master data
set there are usually a couple of records in subreport. It happens
sometimes that there are no records at all in subreport.
I also have a function with one parameter that I declared in Initialize.
This function is called in data element of subreport (f(row["CZAS"])).
When there are no records in subreport function is called with parameter
which value is org.eclipse.birt.data.engine.script.DataExceptionMocker@...
I expect that this function would not be called.
I hope that above explanation is clear.
Robert
Re: Strange exception [message #123055 is a reply to message #122993] Thu, 02 February 2006 08:10 Go to previous messageGo to next message
Robert, this looks like a bug in BIRT. Can you please file a bugzilla bug
and attach the report design that's giving you this error?
thanks,
Gary Xue
Actuate Corporation - Product Development
BIRT Committer
"Robbo" <r.budner@abg.com.pl> wrote in message
news:drsrib$v9o$1@utils.eclipse.org...
> Hi.
> Robert
Re: Strange exception [message #177864 is a reply to message #122993] Sat, 15 July 2006 08:46 Go to previous message
Originally posted by: kevin_ou.yahoo.com
I got the same error in the 2.1 .
Do you have anyway to work around that problem?
Kevin
> Hi.
> bound to its corresponding data set. First table is a master table and the
> second is a subreport (inner) table. The two data sets are additionaly
> linked together (join). So, for each record in master data set there are
> usually a couple of records in subreport. It happens sometimes that there
> Robert
Previous Topic:Wat to change the datasource at runtime
Next Topic:Nested tables - do they work?
Current Time: Tue Nov 04 19:24:28 EST 2025
Powered by FUDForum. Page generated in 0.04078 seconds
