Home » Archived » BIRT » BIRT Runtime 4.6 under tomcat 7, unable to run test report( java.lang.IllegalArgumentException: Choice Pattern incorrect:)
BIRT Runtime 4.6 under tomcat 7, unable to run test report [message #1778527] Fri, 15 December 2017 12:44 Go to next message
Hello guys,
After installing the BIRT Runtime 4.6.0 under Tomcat 7 on Linux I'm getting a strange error while running the test report.
- java.lang.IllegalArgumentException: Choice Pattern incorrect: 0#|1#{1}|2#{1},{2}|3#{1},{2},{3}
AxisFault
 faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
 faultSubcode:
 faultString: java.lang.IllegalArgumentException: Choice Pattern incorrect: 0#|1#{1}|2#{1},{2}|3#{1},{2},{3}
 faultActor:
 faultNode:
 faultDetail:
	{http://xml.apache.org/axis/}stackTrace:java.lang.IllegalArgumentException: Choice Pattern incorrect: 0#|1#{1}|2#{1},{2}|3#{1},{2},{3}
	at java.text.MessageFormat.makeFormat(MessageFormat.java:1510)
	at java.text.MessageFormat.applyPattern(MessageFormat.java:479)
	at java.text.MessageFormat.<init>(MessageFormat.java:363)
	at java.util.Locale.formatList(Locale.java:1978)
	at java.util.Locale.getDisplayName(Locale.java:1825)
	at java.util.Locale.getDisplayName(Locale.java:1737)
	at org.eclipse.birt.report.engine.api.impl.EngineTask.setLocale(EngineTask.java:299)
	at org.eclipse.birt.report.service.ReportEngineService.runReport(ReportEngineService.java:1289)
	at org.eclipse.birt.report.service.BirtViewerReportService.runReport(BirtViewerReportService.java:159)
	at org.eclipse.birt.report.service.actionhandler.BirtRunReportActionHandler.__execute(BirtRunReportActionHandler.java:81)
	at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
	at org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.doService(FramesetFragment.java:191)
	at org.eclipse.birt.report.presentation.aggregation.layout.FramesetFragment.service(FramesetFragment.java:86)
	at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(ViewerServlet.java:181)
	at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.java:160)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.java:68)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
	at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1078)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
	at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2454)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalArgumentException
	at java.text.ChoiceFormat.applyPattern(ChoiceFormat.java:221)
	at java.text.ChoiceFormat.<init>(ChoiceFormat.java:311)
	at java.text.MessageFormat.makeFormat(MessageFormat.java:1507)
	... 40 more
Any idea what is causing this?
Thank you in advance
Re: BIRT Runtime 4.6 under tomcat 7, unable to run test report [message #1783213 is a reply to message #1778527] Fri, 09 March 2018 04:14 Go to previous message
Any help on this?
Previous Topic:Problem with percentage calculations
Next Topic:How to show images in column ,based on another column value in BIRT
Current Time: Sun Jul 27 14:08:15 EDT 2025
Powered by FUDForum. Page generated in 0.03595 seconds
