Home » Eclipse Projects » Eclipse Scout » Memory leak in table fields
Memory leak in table fields [message #1778506] Fri, 15 December 2017 05:35 Go to next message
It seems like there may be a memory leak in tables that update often.
In Table.js, there is an array _updatedRows which stores all rows that have been updated during the lifetime of the table field:
scout.TableField.prototype._onTableChanged = function(event) {
  if (event.type === 'rowsUpdated') {
    scout.arrays.pushAll(this._updatedRows, event.rows);
    return;
However, since it's an array, it will keep growing for every row that has been touched in any way. Our table can have up to 200 rows that update every second, resulting in a... quite big heap in a short time.
Suggestion:
Could _updatedRows perhaps be removed in favor of simply setting touched to true?
[Updated on: Fri, 15 December 2017 08:48] by Moderator
Re: Memory leak in table fields [message #1778594 is a reply to message #1778506] Mon, 18 December 2017 06:51 Go to previous message
Hi Simon
Thank you for your feedback! This is a memory leak indeed. It will be fixed with the next builds for the 6.1, 7.0 and 7.1 branches.
If you are interested in the solution, check out the commit: https://git.eclipse.org/c/scout/org.eclipse.scout.rt.git/commit/?h=releases/6.1.x&id=ecd78e68082f8f7ccddc4c424a647a3ac6c5e87a
Best regards
Claudio
Previous Topic:Checkbox of checkable table disappearing
Next Topic:Custom login on scout
Current Time: Sat Jul 26 23:39:03 EDT 2025
Powered by FUDForum. Page generated in 0.03984 seconds
