Home » Language IDEs » ServerTools (WTP) » Unable to open any non-Eclipse generated WSDLs
Unable to open any non-Eclipse generated WSDLs [message #177772] Wed, 23 August 2006 09:27 Go to next message
Originally posted by: Sarwar_Raza.3Com.com
I've been unable to use WTP (1.5 w/ Eclipse 3.2) WSDL editor to view any
WSDLs except those created using WTP. Is this is a known issue? It seems to
throw the same exception everytime, no matter what WSDL I attempt to open
(File-->Open File).
Stack trace attached.
\Sarwar
Unable to create this part due to an internal error. Reason for the failure:
org.eclipse.ui.internal.editors.text.JavaFileEditorInput
java.lang.ClassCastException:
at
org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.buil dAndSetModel(ASDMultiPageEditor.java:128)
at
org.eclipse.wst.wsdl.ui.internal.asd.ASDMultiPageEditor.crea tePages(ASDMultiPageEditor.java:106)
at
org.eclipse.wst.wsdl.ui.internal.InternalWSDLMultiPageEditor .createPages(InternalWSDLMultiPageEditor.java:347)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:276)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2588)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2470)
at
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:132)
at
org.eclipse.ui.internal.editors.text.OpenExternalFileAction. run(OpenExternalFileAction.java:100)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
at
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Unable to open any non-Eclipse generated WSDLs [message #177789 is a reply to message #177772] Wed, 23 August 2006 10:47 Go to previous messageGo to next message
Sarwar,
Many editors don't support any input other the IFileEditorInput, i.e.,
they can only be opened for resources in the workspace. So put yours
WSDLs in a project and it should work fine.
>(File-->Open File).
>Thanks
>\Sarwar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Unable to open any non-Eclipse generated WSDLs [message #177850 is a reply to message #177789] Thu, 24 August 2006 18:54 Go to previous message
Thanks Ed. Adding it to the project made the problem go away.
Works like a charm now.
\Sarwar
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:echpq2$35b$2@utils.eclipse.org...
> Sarwar,
>>to throw the same exception everytime, no matter what WSDL I attempt to
>>open (File-->Open File).
>>Thanks
>>\Sarwar
>>failure: org.eclipse.ui.internal.editors.text.JavaFileEditorInput
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Previous Topic:javax.servlet in tomcat plugin
Next Topic:Can a bottom up web service be created from an interface definition ?
Current Time: Wed Jul 23 11:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.06959 seconds
