Home » Eclipse Projects » DTP » How to execute driver XML ODA assemblage?
How to execute driver XML ODA assemblage? [message #1778087] Sat, 09 December 2017 11:57 Go to next message
Hi!
I am engaged in modelling in the environment of Eclipse Sirius and I want to use BIRT for documenting of models. For this purpose I need to develop driver ODA for files *.aird which contain the graphic information of models.
The file *.aird is a specialisation of a file *.xml, and BIRT it reads, but cannot present the graphic information from *.aird.
I see two ways of the decision of a problem:
1. To Include in each template of the report processing of interruptions, reformative the information of a picture from *.aird in a picture which understands BIRT (I it did).
2. To Realize expansion ODA which will do it automatically. Simultaneously it is possible to simplify essentially UI, having relieved standard xml UI for BIRT from unnecessary in *.aird elections.
At the improvements ВIRT I use book Integrating and Extending BIRT, authors Jason Weathersby, Tom Bondur and Iana Chatalbasheva. Initial code DTP and BIRT has downloaded from site Eclipse
I wanted to execute assemblage of projects org.eclipse.birt.report.data.oda.xml and org.eclipse.birt.report.data.oda.xml.ui, and then to make necessary changes and additions.
Unfortunately, I did not manage to achieve working capacity of assemblage. I think, I did not manage to establish correctly an option in MANIFEST.
Whether prompt to me somewhere I, please, can download these projects with the information on assemblage.
Thank you very much.
Leonid
lnew@yandex.ru
Re: How to execute driver XML ODA assemblage? [message #1778450 is a reply to message #1778087] Thu, 14 December 2017 05:25 Go to previous message
Hi!
All thanks! The problem is solved.
Previous Topic:Show Errors on Oracle PL/SQL compile?
Next Topic:Oracle Data Table menu missing
Current Time: Mon Jul 28 17:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.65786 seconds
