Home » Eclipse Projects » Equinox » Servet bridge: tomcat severe logs about possible memory leak
Servet bridge: tomcat severe logs about possible memory leak [message #1777851] Tue, 05 December 2017 05:18 Go to next message
Stopping an application built on top of servlet bridge, deployed on tomcat 8.5
I can find these SEVERE level logs
SEVERE [http-nio-8088-exec-3] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [app] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@473cab84]) and a value of type [org.eclipse.osgi.internal.loader.classpath.ClasspathManager.DefineContext] (value [org.eclipse.osgi.internal.loader.classpath.ClasspathManager$DefineContext@7ade541c]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Even I am pretty sure tomcat is managing this so there is no really a memory leak, but having something SEVERE in logging is not really cleaned.
Also clicking on leak detector on tomcat manager give this
05-Dec-2017 11:37:44.149 SEVERE [http-nio-8088-exec-13] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [app] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1179aeb8]) and a value of type [org.eclipse.osgi.internal.weaving.WeavingHookConfigurator.WovenClassContext] (value [org.eclipse.osgi.internal.weaving.WeavingHookConfigurator$WovenClassContext@7b5a8a18]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
Is there something I could do to avoid these ? it seems to me that the cause could be something internal to equinox in servlet bridge.
[Updated on: Tue, 05 December 2017 05:43] by Moderator
Re: Servet bridge: tomcat severe logs about possible memory leak [message #1777872 is a reply to message #1777851] Tue, 05 December 2017 08:55 Go to previous messageGo to next message
This appears to be https://bugs.eclipse.org/bugs/show_bug.cgi?id=469549
What version of Equinox are you using. Do you use any subclasses of ThreadLocal?
Re: Servet bridge: tomcat severe logs about possible memory leak [message #1777874 is a reply to message #1777872] Tue, 05 December 2017 09:00 Go to previous messageGo to next message
Actually this is probably https://bugs.eclipse.org/bugs/show_bug.cgi?id=411714 and it looks like it is still an issue with the latest. Seems we must stop using subclasses of ThreadLocal in weaving to fix this.
Re: Servet bridge: tomcat severe logs about possible memory leak [message #1777881 is a reply to message #1777874] Tue, 05 December 2017 10:09 Go to previous message
sorry I forgot to mention I am using Equinox from Oxygen.1
Previous Topic:Unhandled event loop exception - interface is not visible from class loader
Next Topic:Error updating product with p2
Current Time: Fri Jul 18 15:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.07384 seconds
