| USB and Binding [message #1776935] |
Wed, 22 November 2017 19:11  |
Dear community,
I'm trying to adapt some code for my weather station (TE923).
For that I need to have a direct access to USB.
As I want to share the code - and potentially propose to integrate it in eclipse.smarthome - what is the library I should use?
Thank you,
Gabriel
| Re: USB and Binding [message #1777017 is a reply to message #1776986] |
Thu, 23 November 2017 10:52   |
Ok, I see. If you need "pure" USB support, then RXTX won't help you any further.
The only USB library I have come across so far is http://usb4java.org/ - I do not have any experience with it myself, though. If this is what you need, we can certainly discuss adding it to the stack.
Regarding your questions:
It depends. If you feel that the binding is important for other solutions (e.g. commercial ones) than openHAB, ESH would be the right place. Otherwise, contributing to openhab2 is easier (as it involved less work on the project management side for me). If in doubt, my general suggestion is to contribute it to openhab2 and if somebody else is interested in using it, it can be easily moved over to ESH (we have done so for Sonos and Astro binding already). For TE923, I would tend to say that openhab2 might be the better choice.
Kai
| Re: USB and Binding [message #1777482 is a reply to message #1777017] |
Wed, 29 November 2017 10:42   |
I apologize if it appears I am hijacking this thread - I'll start a new one instead if you suggest it...
I have a USB-connected Arduino that executes my own home-brewed sketch to give me various automations in my house. The host computer runs Ubuntu CLI (Command Line Interface, no GUI), thus I am currently confined to ssh and command line only monitoring and control. I have no off-the-shelf commercial IoT devices whatsoever, and by implication, no UPnP or otherwise discoverable devices. Still, I hoped to fashion a html interface mapped to the Arduino so it could be http controlled. I plan to use OpenHAB "Exec" [binding] to shim between GUI and CLI. OpenHAB2 seemed to be the direction I wanted to go (we'll assume RXTX will link adequately when I install it later), but for the life of me I can't grasp how to reconcile in concept the delineations of Thing and Item (and etc.!) in this environment where a single micro controller is the communications path between multiple disparate-functionality Items. That is due, in part, to a light bulb being called an Item in the Concepts Overview section2 of the OpenHAB user docs but called a Thing in their Concepts Things section. I ask in Eclipse forum because Eclipse authored the words in the first place.
Can you please help me though my mental block so I can start laying out something workable in a "micro controller-fanning-to-many monitored and controlled devices" environment? Perhaps you might enlighten me whether "Categorizing a physical device as an Item or a Thing in some scenarios can be a matter of preference, and the existence of Items are not necessarily mandatory" to explain why a light bulb is said to be an Item, then a Thing?
My system details:
SITUATION 1: To query room temperature, my server sends some text commands to the Arduino, then waits for a response, parses out the temperature, and outputs that temp to STDOUT (CLI right now). I would like mere browser rendering of the thermostat image to also send a CLI temperaure query command and render the STDOUT result. Note that the Arduino is fully a thermostat and controls the furnace and A/C, therefore it receives from and returns to the host its temperature settings and state of the furnace/fan and A/C outputs. In addition to returning information when queried, the Arduino sends info of its own accord, mostly so the furnace on/off times can be logged by the server. I'd like the thermostat image in the user's browser to show the state of the furnace, not only when the image is first rendered, but also updated as the Arduino sends the pertinent info back to server.
SITUATION 2: Server host sends commands on a crontab-run schedule to Arduino to turn outlet on/off to the coffee maker. Same scenario for the porch light. I'd like a [remote] user to have an icon (or mouse clickable screen region by whatever name) whereby the outlets could be remote controlled and read. Arduino-initiated logging info also gets sent back to host to alert of possible on-off state changes not initiated by the host.
Thank you!
| Re: USB and Binding [message #1777878 is a reply to message #1777866] |
Tue, 05 December 2017 09:43  |
Thank you much, Kai.
However, I still seem to find so many concepts stated from a vantage point that makes it difficult to reconcile them with a DIY automation system that has different functionalities designed differently into its physical and virtual devices than the commercial examples used. But I'm way too tenacious, passionate, and desperate to give up before I figure it out, so I will succeed eventually.
Blessings.
[Updated on: Tue, 05 December 2017 10:42] by Moderator
FUDForum. Page generated in 0.07041 seconds
