Home » Modeling » TMF (Xtext) » How to delete generated files(I would like to delete the previously generated files if they aren't generated again)
How to delete generated files [message #1777505] Wed, 29 November 2017 13:59 Go to next message
On save I would like to delete the previously generated files if they aren't generated again.
I have a flag that determines if a file should be generated or not. If some file was generated, but after the user turn the flag off and save again, that old file must be deleted. There is a way to do this using the Xtext plug-in?
Re: How to delete generated files [message #1777507 is a reply to message #1777505] Wed, 29 November 2017 14:05 Go to previous messageGo to next message
Hi, i am not sure if i can follow you. you can have a look at org.eclipse.xtext.builder.BuilderParticipant.cleanDerivedResources(Delta, Set<IFile>, IBuildContext, EclipseResourceFileSystemAccess2, IProgressMonitor) or org.eclipse.xtext.builder.BuilderParticipant.getDerivedResources(Delta, Map<String, OutputConfiguration>, Map<OutputConfiguration, Iterable<IMarker>>)
Re: How to delete generated files [message #1777508 is a reply to message #1777507] Wed, 29 November 2017 14:30 Go to previous messageGo to next message
Hi thank you for the quick reply.
The method getDerivedResources returns an empty list, but I have files generated and others that should be deleted.
Re: How to delete generated files [message #1777509 is a reply to message #1777508] Wed, 29 November 2017 14:33 Go to previous messageGo to next message
Can you give some more insights on what you are doing inside your generator
Re: How to delete generated files [message #1777517 is a reply to message #1777509] Wed, 29 November 2017 16:09 Go to previous messageGo to next message
Nothing special, I'm using default output configuration and calling:
def protected void generateFile(String fileName, CharSequence contents) {
    fsa.generateFile(fileName, contents);
Re: How to delete generated files [message #1777519 is a reply to message #1777517] Wed, 29 November 2017 16:13 Go to previous messageGo to next message
but this works out of the box
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID doNotGenerate?='skip'? '!';
class MyDslGenerator extends AbstractGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		for (g : resource.allContents.filter(Greeting).toIterable.filter[!isDoNotGenerate]) {
			fsa.generateFile(g.name+".txt",'''«g.name»''')
add a skip to a greeting and generated file will go away
Re: How to delete generated files [message #1777618 is a reply to message #1777519] Thu, 30 November 2017 15:44 Go to previous message
Hi thanks for your reply.
The problem was happening because I'm changing the outputDirectory to '.' at doGenerate method. But the outputDirectory in BuilderParticipant.build method was being created with "./src-gen", so it wasn't deleting the expected old files because directories are different. The solution was to do like described in https://stackoverflow.com/questions/10350022/how-to-add-multiple-outlets-for-generated-xtext-dsl.
Now it is deleting not generated files as expected.
Previous Topic:Parsing from a tree
Next Topic:java.lang.RuntimeException: path to .genmodel is unmapped
Current Time: Fri Jul 25 23:57:36 EDT 2025
Powered by FUDForum. Page generated in 0.28758 seconds
