Home » Newcomers » Newcomers » avr-gdb failed to launch(gdbinit:1: Error in sourced command file:\nNo symbol table is loaded)
avr-gdb failed to launch [message #1777616] Thu, 30 November 2017 14:18 Go to next message
Hi all,
after having setup externals tools configuration for simulavr (starting it is OK), tried to setup the Debug Configuration for avr-gdb.
- In GDB Command was setting the path to the avr-gdb file and the avr-gdb command.
- in the startup tab I ticked "Load symbols" and entered the workspace path and the file name of the project-elf file in "use file".
- the .gdbinit file contains one command: "set startup-with-shell off"
Now, when I press "Debug" in the debug configuration window, I get the error: "Error in final launch sequence" with details as follows:
Failed to execute MI command:
source /Users/../.gdbinit
Error message from debugger back end:
/Users/../.gdbinit:1: Error in sourced command file:\nNo symbol table is loaded. Use the "file" command.
setup was done according to:
http://avr-eclipse.sourceforge.net/wiki/index.php/Debugging
avr-gdb version is 7.6.1 from within CrossPack-AVR-20131216
System is MacOS High Sierra 10.13.1
Thank you for any help.
Re: avr-gdb failed to launch [message #1777635 is a reply to message #1777616] Fri, 01 December 2017 02:28 Go to previous messageGo to next message
This is not a Eclipse project so I'm not sure anyone here can help with that.
Re: avr-gdb failed to launch [message #1777653 is a reply to message #1777635] Fri, 01 December 2017 04:38 Go to previous message
Thank you Ed,
I have now posted the question in source forge in the avr plugin discussion section.
Previous Topic:Crosscompiler error - missing path ?
Next Topic:What does Google Crome proposed code blocking mean for Java EE Tomcat development
Current Time: Mon Jul 21 02:33:30 EDT 2025
Powered by FUDForum. Page generated in 0.13417 seconds
