Home » Eclipse Projects » JFace » jface wizard becomes not responding
jface wizard becomes not responding [message #1777426] Wed, 29 November 2017 05:36 Go to next message
I've implemented a jface wizard in my swt application. In one page of this wizard a time-consuming operation is monitored by the wizard's progress monitor as follows:
getContainer().run(true, false, new IRunnableWithProgress() {
	public void run(IProgressMonitor monitor)
		throws InvocationTargetException, InterruptedException {
monitor.beginTask("", IProgressMonitor.UNKNOWN);
      getShell().getDisplay().asyncExec(new Runnable() {
	public void run() {
					//my operation
monitor.done();
The problem is that the application becomes not responding a little while after the operation starts. It seems that the fork parameter has no effect, becuase my operation is executed by the UI thread!!!
Re: jface wizard becomes not responding [message #1777452 is a reply to message #1777426] Wed, 29 November 2017 08:15 Go to previous messageGo to next message
Are you sure you need to execute "my operation" in the UI thread?
You should not run code in the UI thread when forking (from UI thread).
If you are not sure, remove the call to the Display.async() method and execute the "my operation" code directly. If you get invalid thread access exceptions, then you need to call only that instruction in the UI thread.
Ali Sedaghat wrote on Wed, 29 November 2017 11:36
	public void run() {
					//my operation
monitor.done();
Re: jface wizard becomes not responding [message #1777481 is a reply to message #1777452] Wed, 29 November 2017 10:29 Go to previous message
Thank you
Previous Topic:jface wizard becomes not responding
Next Topic:[SOLVED] RTL support for Wizards or TreeViewers?
Current Time: Fri Jul 25 19:51:37 EDT 2025
Powered by FUDForum. Page generated in 0.03760 seconds
