Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse 4.7 and Tycho
Eclipse 4.7 and Tycho [message #1777445] Wed, 29 November 2017 07:36 Go to next message
Hello everyone, I recently migrated an application from Eclipse 3.7 to Eclipse 4.7 using the Compatibility Layer. Now add the use of Tycho to deploy the application. The application defines target platform and features.
I managed to get all the errors, I only have the following:
No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from com.zetti.ftpos.features.feature.group 1.0.0.qualifier to com.zetti.ftpos.product.deploy 0.0.0.; Unable to satisfy dependency from org.eclipse.jdt.core 3.13.0.v_OTDT_r260_201706061122 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; No solution found because the problem is unsatisfiable.]
I have investigated that it is recommended to add dependency to the parent POM
<properties>
		<tycho-version>1.0.0</tycho-version>
		<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
	</properties>
	<build>
		<plugins>
			<plugin>
				<groupId>org.eclipse.tycho</groupId>
				<artifactId>target-platform-configuration</artifactId>
				<version>${tycho-version}</version>
				<configuration>
	            <dependency-resolution>
	               <extraRequirements>
	                   <requirement>
	                       <type>p2-installable-unit</type>
	                       <id>org.eclipse.jdt.feature.group</id>
	                       <versionRange>0.0.0</versionRange>
	                   </requirement>
	               </extraRequirements>
	           </dependency-resolution>
                    <target>
                        <artifact>
                            <groupId>com.zetti.ftpos</groupId>
                            <artifactId>ftpos</artifactId>
                            <version>1.0.0-SNAPSHOT</version>
                        </artifact>
                    </target>
					<environments>
						<environment>
							<os>linux</os>
							<ws>gtk</ws>
							<arch>x86</arch>
						</environment>
						<environment>
							<os>linux</os>
							<ws>gtk</ws>
							<arch>x86_64</arch>
						</environment>
						<environment>
							<os>win32</os>
							<ws>win32</ws>
							<arch>x86</arch>
						</environment>
						<environment>
							<os>win32</os>
							<ws>win32</ws>
							<arch>x86_64</arch>
						</environment>
						<environment>
							<os>macosx</os>
							<ws>cocoa</ws>
							<arch>x86_64</arch>
						</environment>
					</environments>
				</configuration>
			</plugin>
            <plugin>
                <artifactId>tycho-maven-plugin</artifactId>
                <extensions>true</extensions>
            </plugin>
		</plugins>
	</build>
Even so I continue with the same error
Some clue?
Thanks in advance!.
Eclipse 4.7 Oxygen
Tycho 1.0.0
Java 1.8
Mariano
[Updated on: Wed, 29 November 2017 14:56] by Moderator
Re: Eclipse 4.7 and Tycho [message #1777506 is a reply to message #1777445] Wed, 29 November 2017 14:02 Go to previous messageGo to next message
Hi there,
please be aware that this just is a very wild and uninformed guess ... are you sure you really need or want to follow through with "satisfying this dependency"?
i just did search in google with the term "org.eclipse.objectteams.otdt.core.patch" and arrived at https://bugs.eclipse.org/bugs/show_bug.cgi?id=350133
If i understand the comments correctly they talk about an update path in 3.7 which allows for unneeded/-necessary/-wanted installation of said patch feature.
Maybe you could just continue without the burden of satisfying this dependency?
cheers
Daniel
/edit:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350133#c40
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350133#c55
this comments and the surrounding talk might also be helpful
[Updated on: Wed, 29 November 2017 14:12] by Moderator
Re: Eclipse 4.7 and Tycho [message #1777569 is a reply to message #1777506] Thu, 30 November 2017 06:49 Go to previous messageGo to next message
Thanks for answering, I had already read the error that you mention, the problem in this case is that it is the only mistake I have to execute the deployment by Tycho. When throwing the exception the deploy is stopped, that's why I have to fix it.
Best Regards
Mariano
  • Attachment: tycho.log
    (Size: 138.31KB, Downloaded 104 times)
Re: Eclipse 4.7 and Tycho [message #1777592 is a reply to message #1777445] Thu, 30 November 2017 11:00 Go to previous messageGo to next message
Please be aware of my humble disclaimer that i do not concern me as someone who should be answering your question ... i am really not well experienced in the workings of tycho ... i merely try to "think alongside" and reply with my thoughts. It would be great if you would get answers from someone more experienced with tycho than myself!
Concerning your problem:
What log does your build produce if you apply the dependency-filter mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=350133#c40 adjusted to the version of jdt.core in your logs?
<plugin>
   <configuration>
      <filters>
         <filter>
            <type>eclipse-plugin</type>
            <id>org.eclipse.jdt.core</id>
            <restrictTo>
               <version>3.13.0.v_OTDT_r260_201706061122</version>
            </restrictTo>
         </filter>
      </filters>
   </configuration>
</plugin>
https://wiki.eclipse.org/Tycho/Target_Platform#Filtering
Cheers
Daniel
Re: Eclipse 4.7 and Tycho [message #1777608 is a reply to message #1777592] Thu, 30 November 2017 12:39 Go to previous messageGo to next message
I tried your advice but I still have the same error.
Attached the log.
Best Regards
Mariano
    (Size: 139.28KB, Downloaded 116 times)
Re: Eclipse 4.7 and Tycho [message #1777619 is a reply to message #1777608] Thu, 30 November 2017 16:02 Go to previous messageGo to next message
I think i "censored" out a relevant detail and also replaced the version wrong ... i think i put in "offending" plugin-version-stuff instead of the "wanted" plugin version. You probably need to find out the version of org.eclipse.jdt.core like he mentioned - adapt to other release trains (e.g. probably oxygen?) / service releases (e.g. SR1a?) and use that instead of my example.
Also I left out Jans commented advice . Jan mentioned:
<!-- this is the version for Kepler SR1, have to adapt for other release trains/service releases -->
<restrictTo>
    <version>3.9.1.v20130905-0837</version>
</restrictTo>
I still think filtering might be able to help you ... but i have no clue how to find out said adapted version.
cheers
Daniel
//edit:
despite my uninitiated guesses you might also try to find help in the tycho-users mailing list. https://accounts.eclipse.org/mailing-list/tycho-user
[Updated on: Thu, 30 November 2017 16:06] by Moderator
Re: Eclipse 4.7 and Tycho [message #1777680 is a reply to message #1777619] Fri, 01 December 2017 07:22 Go to previous messageGo to next message
Thank you very much Daniel !, you were right, I needed to set the jdt.core version correctly.
 <filters>
        <filter>
                   <restrictTo>
                   <version>3.13.0.v20170516-1929</version>
                   </restrictTo>
        </filter>
</filters>
I still can not perform the deploy because of the error:
Bundle-ClassPath entry icu-data.jar does not exist in /.m2/repository/p2/osgi/bundle/com.ibm.icu/58.2.0.v20170418-1837/com.ibm.icu-58.2.0.v20170418-1837.jar
Try a couple of tips that they mention in
http://tycho-user.eclipse.narkive.com/1LXKrPt0/nested-jars-in-dependency-issue
But it does not work...
Any clues?.
Best Regards.
Mariano.
[Updated on: Fri, 01 December 2017 14:34] by Moderator
Re: Eclipse 4.7 and Tycho [message #1777803 is a reply to message #1777680] Mon, 04 December 2017 12:26 Go to previous message
To eliminate this error, what I did was add the package to the p2 site generated:
<artifact> <id> com.ibm.icu:icu4j:58.2 </ id> <override> true </ override> </ artifact>
Instead of importing the whole org.eclipse.ui package, what I did was import the specific package that requires e.g. org.eclipse.ui.ide.
I hope it serves someone.
Best Regards.
Mariano.
[Updated on: Tue, 05 December 2017 06:48] by Moderator
Previous Topic:Eclipse RCP and Java 9 results in NoClassDefFoundError
Next Topic:Is it possible to simulataneously launch multiple instances of an RCP with different ini file
Current Time: Wed Jul 23 12:48:36 EDT 2025
Powered by FUDForum. Page generated in 0.09502 seconds
