Home » Modeling » TMF (Xtext) » Parsing Exponent Expression
Parsing Exponent Expression [message #1777341] Tue, 28 November 2017 11:10 Go to next message
Hello.
I am strugging to parse an exponent expression.
My issue is that the "nested" exponent expression is not being parsed.
Please refer to the attached screenshots for detail.
Request:
What changes do I need to make to the grammer (below) to be able to parse the nested exponent expression?
Addtional Information:
Precedence of expression:
  • AND
  • OR
	@Test def void testExponentiation() {
		"2**3**4".assertRepr("(2 ** (3 ** 4))")
	def private String stringRepr(Expression e) {
		switch (e) {
			Plus: '''(«e.left.stringRepr» + «e.right.stringRepr»)'''
			Minus: '''(«e.left.stringRepr» - «e.right.stringRepr»)'''
			MulOrDiv: '''(«e.left.stringRepr» «e.op» «e.right.stringRepr»)'''
			Exponent: '''(«e.left.stringRepr» ** «e.right.stringRepr»)'''
			Comparison: '''(«e.left.stringRepr» «e.op» «e.right.stringRepr»)'''
			Equality: '''(«e.left.stringRepr» «e.op» «e.right.stringRepr»)'''
			And: '''(«e.left.stringRepr» AND «e.right.stringRepr»)'''
			Or: '''(«e.left.stringRepr» OR «e.right.stringRepr»)'''
			Not: '''(NOT «e.expression.stringRepr»)'''
			IntConstant: '''«e.value»'''
			StringConstant: '''«e.value»'''
			BoolConstant: '''«e.value»'''
		}.toString
Model:
	expressions+=AbstractExpression*
AbstractExpression:
	'EVAL' 'foo' '=' expression=Expression ';';
Expression: Or;
Or returns Expression:
	And (
		{Or.left=current} 'OR'
		right=And
And returns Expression:
	Equality (
		{And.left=current} 'AND'
		right=Equality
Equality returns Expression:
	Comparison (
		{Equality.left=current} op=('=' | '<>')
		right=Comparison
Comparison returns Expression:
	PlusOrMinus (
		{Comparison.left=current} op=('>=' | '<=' | '>' | '<')
		right=PlusOrMinus
PlusOrMinus returns Expression:
	MulOrDiv (
		({Plus.left=current} '+' | {Minus.left=current} '-')
		right=MulOrDiv
MulOrDiv returns Expression:
	Exponent (
		({MulOrDiv.left=current} op=('*' | '/'))
		right=Exponent
Exponent returns Expression:
	Primary (
		{Exponent.left=current} '**' right=Primary)?;
Primary returns Expression:
	'(' Expression ')' |
	{Not} 'NOT' expression=Primary |
	Atomic;
Atomic returns Expression:
	{IntConstant} value=INT	|
	{StringConstant} value=STRING |
	{BoolConstant} value=('*ON' | '*OFF') ;
Re: Parsing Exponent Expression [message #1777349 is a reply to message #1777341] Tue, 28 November 2017 12:13 Go to previous messageGo to next message
Why questionmark
Primary (
Re: Parsing Exponent Expression [message #1777453 is a reply to message #1777349] Wed, 29 November 2017 08:28 Go to previous messageGo to next message
@Christian. Well spotted.
Changed the "?" to "*" now it does parse the expression but the nesting is in the wrong order ( refer attached screenshot). I need to change the "association" from left to right, but I am unsure how to. Can you advise?
	Primary (
		right=Primary
[Updated on: Wed, 29 November 2017 08:30] by Moderator
Re: Parsing Exponent Expression [message #1777456 is a reply to message #1777453] Wed, 29 November 2017 08:37 Go to previous messageGo to next message
then you have to do it the other way round e.g
Primary
right=Exponent
Re: Parsing Exponent Expression [message #1777460 is a reply to message #1777456] Wed, 29 November 2017 09:02 Go to previous messageGo to next message
Thanks. The change worked, parsing as expected. All other unit tests also passed.
But... During the generation of the Langauge 2 warnings are generated (reference screenshot below).
Should I be concerned about them?
[Updated on: Wed, 29 November 2017 09:03] by Moderator
Re: Parsing Exponent Expression [message #1777461 is a reply to message #1777460] Wed, 29 November 2017 09:03 Go to previous messageGo to next message
do you have a complete grammar as is now?
Re: Parsing Exponent Expression [message #1777463 is a reply to message #1777461] Wed, 29 November 2017 09:09 Go to previous messageGo to next message
The grammar is not final yet. Guessing only 30% done.
Re: Parsing Exponent Expression [message #1777464 is a reply to message #1777463] Wed, 29 November 2017 09:12 Go to previous messageGo to next message
i need something to reproduce
Re: Parsing Exponent Expression [message #1777467 is a reply to message #1777464] Wed, 29 November 2017 09:21 Go to previous messageGo to next message
Please find attached the Grammer file.
Spoke to soon, the change broke the maven build.
This test method, used to pass but now fails.
	@Test def void testByteSize_DataTypeWithBytes_00() {
		'''DCL-S foo varchar(1  )'''.parse => [ m |	m.assertNoErrors]
		'''DCL-S foo varchar(1:2)'''.parse => [ m |	m.assertNoErrors]
		'''DCL-S foo varchar(1:4)'''.parse => [ m |	m.assertNoErrors]
		'''DCL-S foo vargraph(1  )'''.parse => [ m | m.assertNoErrors]
		'''DCL-S foo vargraph(1:2)'''.parse => [ m | m.assertNoErrors]
		'''DCL-S foo vargraph(1:4)'''.parse => [ m | m.assertNoErrors]
		'''DCL-S foo varucs2(1  )'''.parse => [ m |	m.assertNoErrors]
		'''DCL-S foo varucs2(1:2)'''.parse => [ m |	m.assertNoErrors]
		'''DCL-S foo varucs2(1:4)'''.parse => [ m |	m.assertNoErrors]
  • Attachment: XRPGLE.xtext
    (Size: 5.25KB, Downloaded 97 times)
[Updated on: Wed, 29 November 2017 09:22] by Moderator
Re: Parsing Exponent Expression [message #1777468 is a reply to message #1777467] Wed, 29 November 2017 09:33 Go to previous messageGo to next message
why
Primary (
right=Exponent
and not
Primary (
right=Exponent
Re: Parsing Exponent Expression [message #1777476 is a reply to message #1777468] Wed, 29 November 2017 09:58 Go to previous messageGo to next message
Made the change form "*" to "?".
Warning gone, Expression Parsing still good.
But the @Test (above) still fails, see attached.
Re: Parsing Exponent Expression [message #1777478 is a reply to message #1777476] Wed, 29 November 2017 10:06 Go to previous messageGo to next message
foo is a keyword ?!? https://blogs.itemis.com/en/xtext-hint-identifiers-conflicting-with-keywords
Re: Parsing Exponent Expression [message #1777480 is a reply to message #1777478] Wed, 29 November 2017 10:12 Go to previous message
Whoops... 'foo' was not meant to be a keyword.
Thanks for all the help.
Previous Topic:How to leverage _trace to properly configure "Open Source/Generated File"
Next Topic:Questions about two problems with Xpect
Current Time: Fri Jul 25 23:08:22 EDT 2025
Powered by FUDForum. Page generated in 0.06490 seconds
