Home » Eclipse Projects » Kura » Raspberry pi B, kura, mqtt(Send mqtt messages from Kura)
Raspberry pi B, kura, mqtt [message #1777063] Fri, 24 November 2017 04:06 Go to next message
Good morning, I have a raspberry pi with kura installed and for other hand my computer with "mosquitto" (a mqtt broker). I´m tryng to send a mqtt message from my raspberry to mosquitto, the problem is:
-To test how works mqtt, i write a simple example in java with eclipse to send a mqtt msg.
    try {
    	System.out.println(1);
	    MqttClient client = new MqttClient("tcp://192.168.0.116:1883",
            MqttClient.generateClientId());
	    client.connect();
    	    System.out.println(2);
	    MqttMessage message = new MqttMessage();
	    message.setPayload(messageString.getBytes());
	    client.publish("test", message);
	    System.out.println("\tMessage '"+ messageString +"' to 'test'");
	    client.disconnect();
	    System.out.println("== END PUBLISHER ==");
    }catch(Exception e){
    	System.out.println(e.getMessage());
And it works, in mosquitto i can see the msg.
I write helloword example follow doc (tested and works show msg in kura-console), now with this example I wanted to test send mqtt msg with kura. I configure kura project, export *.jar, generate *.dp and install it using kura interface and all good, without errors.
protected void activate(ComponentContext componentContext) {
    	System.out.println("Start: Hello World");
    	try {
    		String messageString = "Hello World from Java!";
    	    MqttClient client = new MqttClient("tcp://192.168.0.93:1883", MqttClient.generateClientId());
    	    client.connect();
    protected void deactivate(ComponentContext componentContext) {
    	System.out.println("Stop: Hello World");
        s_logger.info("Bundle " + APP_ID + " has stopped!");
But when I go to "Kura->Devices->Bundles" the state is "Installed"instead of "Active" and when I try to start it, show an error
index.php/fa/31384/0/
index.php/fa/31385/0/
Someone has some idea about how can I solve this or how have I to do to send mqtt msg from Kura to mosquito.
All help is wellcome.
Thank.
  • Attachment: error.jpg
    (Size: 22.50KB, Downloaded 834 times)
  • Attachment: error log.jpg
    (Size: 54.06KB, Downloaded 827 times)
Re: Raspberry pi B, kura, mqtt [message #1777296 is a reply to message #1777063] Tue, 28 November 2017 04:05 Go to previous messageGo to next message
I believe you have to wrap paho in your bundle.
As stated in the console, that dependency is missing.
Matteo
Re: Raspberry pi B, kura, mqtt [message #1777753 is a reply to message #1777296] Mon, 04 December 2017 04:27 Go to previous message
I have added paho library in the manifest "org.eclipse.paho.client.mqttv3;version="1.1.0"".
Matteo Maiero wrote on Tue, 28 November 2017 09:05
Matteo
Previous Topic:Can Protocol
Next Topic:Simulator for S7
Current Time: Sun Jul 27 11:54:41 EDT 2025
Powered by FUDForum. Page generated in 0.04797 seconds
