Use the 'org.eclipse.kura.example.publisher' bundle [message #1777029] |
Thu, 23 November 2017 11:41  |
We've added in eclipse, run configurations, the bundle 'org.eclipse.kura.example.publisher' with the check
Then we add the new service 'org.eclipse.kura.example.publisher.Examplepublisher'
Now we expect to see, in console, on the Wires screen, under 'Wire components', to the right of the screen, a new wire component, but it does not look ....
thanks a lot for any suggestion but we are trying to use better Kura
[Updated on: Thu, 23 November 2017 11:43] by Moderator
Re: Use the 'org.eclipse.kura.example.publisher' bundle [message #1777222 is a reply to message #1777072] |
Mon, 27 November 2017 03:53  |
it depends on what you want to achieve: wires was intended to allow rapid prototyping using some simple building blocks and allowing changes over time.
The complete java application can be developed and used when you want something self-contained without the possibility to define different behaviours.
I believe that it depends on the end result you want to achieve and the type of interaction you want to achieve. Furthermore, it depends also on the type of users will interact with your system.
Matteo
FUDForum. Page generated in 0.24323 seconds
