Home » Modeling » Epsilon » Epsilon: How to measure a program's execution time
Epsilon: How to measure a program's execution time [message #1735579] Tue, 21 June 2016 06:05 Go to next message
Is there any command to measure a program's execution time or parts of a program like an operation call, in EOL?
Alireza
[Updated on: Tue, 21 June 2016 06:22] by Moderator
Re: Epsilon: How to measure a program's execution time [message #1735582 is a reply to message #1735579] Tue, 21 June 2016 06:33 Go to previous messageGo to next message
Hi Alireza,
You can use the respective option in the Profiling tab of the launch configuration dialog of your Epsilon program for this.
Dimitris
Re: Epsilon: How to measure a program's execution time [message #1735609 is a reply to message #1735582] Tue, 21 June 2016 08:27 Go to previous messageGo to next message
Hi Dimitris,
Thank you very much.
Kind regards,
Alireza
Re: Epsilon: How to measure a program's execution time [message #1769699 is a reply to message #1735609] Wed, 02 August 2017 14:23 Go to previous messageGo to next message
I need to get the execution time in my EOL code. I also read [1] and [2]. However, they also show the time on the profiling tab. How can I get the execution time of EOL program in its code?
As another question, how can I get cpu and memory usage in the EOL code.
[1]. https://eclipse.org/epsilon/doc/EpsilonProfilingTools.pdf
[2]. https://www.eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.profiling
Re: Epsilon: How to measure a program's execution time [message #1769874 is a reply to message #1769699] Fri, 04 August 2017 07:49 Go to previous messageGo to next message
To get this information you'd need to write a custom tool [1] that uses org.eclipse.epsilon.profiling.Profiler.INSTANCE to retrieve profiling information and standard Java facilities to record memory usage.
On an unrelated note, it would be appreciated if you could use a realistic name instead of "B A" as discussed in https://www.eclipse.org/epsilon/faq/#getting-help
Dimitris
[1] https://www.eclipse.org/epsilon/doc/articles/call-java-from-epsilon/
Re: Epsilon: How to measure a program's execution time [message #1777157 is a reply to message #1769874] Sat, 25 November 2017 03:41 Go to previous messageGo to next message
Hi there,
My tool has interactions with user and I am going to get the pure execution time of the EOL program without the time taken to user response.
I write the below code, However, it is still gives different times in each execution with the same inputs. Would you please help me in this regard?
var startTime = getUserTime();
//end of program
var stopTime = getUserTime();
var elapsedTime : Real = (stopTime - startTime) /1000000;
operation getUserTime() : Integer {
var ManagementFactory = Native("java.lang.management.ManagementFactory");
        var bean  = ManagementFactory.getThreadMXBean( );
        if (bean.isCurrentThreadCpuTimeSupported( ))
        return bean.getCurrentThreadUserTime( );
        else
        return  0;
[Updated on: Sat, 25 November 2017 03:45] by Moderator
Re: Epsilon: How to measure a program's execution time [message #1777249 is a reply to message #1777157] Mon, 27 November 2017 10:14 Go to previous message
I suspect that you'll need to write custom Java tools [1] to interact with the user, which will support recording interaction time so that you can then subtract it from the time recorded by the Epsilon profiling tools.
Dimitris
Previous Topic:Error in importing Epsilon project example
Next Topic:EMF to RELATIONAL transformation using ETL and EMC-JDBC
Current Time: Sat Jul 26 02:51:09 EDT 2025
Powered by FUDForum. Page generated in 0.25006 seconds
