Home » Modeling » TMF (Xtext) » How to extend OpenGeneratedFileHandler to position the cursor in the right region
How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777077] Fri, 24 November 2017 05:37 Go to next message
Hello all,
from one DSL file, I generate several .java files. The problem is that by default OpenGeneratedFileHandler opens a dialog to choose the right generated file.
I would like to use the ._trace to automatically choose the right file and position th cursor in the region of the generated file (and vice versa)
Any pointers that could me achieve that? I guess I must extend OpenGeneratedFileHandler but have no idea to start
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777079 is a reply to message #1777077] Fri, 24 November 2017 05:41 Go to previous messageGo to next message
a simple
// may be def instead of override ?!?
override Class<? extends OpenGeneratedFileHandler> bindOpenGeneratedFileHandler() {
return MyOpenGeneratedFileHandler;
should do the trick
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777091 is a reply to message #1777079] Fri, 24 November 2017 06:24 Go to previous messageGo to next message
Thanks for the reply.
Sorry for the lame question but how will this be intercepted by the eclipe menu. Is it an extension?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777093 is a reply to message #1777091] Fri, 24 November 2017 06:31 Go to previous messageGo to next message
yes i thought you would have found that
	<extension point="org.eclipse.ui.handlers">
		<handler
			class="org.eclipse.xtext.example.homeautomation.ui.RuleEngineExecutableExtensionFactory:org.eclipse.xtext.ui.generator.trace.OpenGeneratedFileHandler"
			commandId="org.eclipse.xtext.ui.OpenGeneratedFileCommand">
			<activeWhen>
				<reference definitionId="org.eclipse.xtext.example.homeautomation.RuleEngine.Editor.opened" />
			</activeWhen>
		</handler>
	</extension>
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777100 is a reply to message #1777093] Fri, 24 November 2017 07:53 Go to previous messageGo to next message
Thanks for the help. Indeed I should have figured out.
Actually there is something strange when I debug OpenGeneratedFileHandler.
The method OpenGeneratedFileHandler either depends upon a traceBasedOpenerCollector or a derivedResourceMarkerBasedOpenerCollector.
Further debugging shows me traceForStorageProvider.getTraceToTarget(editorStorage) returns null.
Is there something to do to use the trace files?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777102 is a reply to message #1777100] Fri, 24 November 2017 07:58 Go to previous messageGo to next message
org.eclipse.xtext.ui.generator.trace.TraceBasedOpenerContributor.collectGeneratedFileOpeners(IEditorPart, IAcceptor<FileOpener>)
should find something
=> debug org.eclipse.xtext.generator.trace.internal.AbstractTraceForURIProvider.getTraceToTarget(SomeFile, AbsoluteURI, IProjectConfig)
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777103 is a reply to message #1777102] Fri, 24 November 2017 08:01 Go to previous messageGo to next message
I think I got it this is probably the reason:
!STACK 0
java.lang.IllegalArgumentException: Produced region is inconsistent with parent, this: TraceRegion [myOffset=318, myLength=142] associations={
  LocationData [TextRegionWithLineInformation [107:54][lineNumber=8, endLineNumber=10]][path=Forex-1.0.0.wkfs]
}, parent: TraceRegion [myOffset=0, myLength=457] associations={
} nestedRegions={
  TraceRegion [myOffset=177, myLength=140] associations={
	at org.eclipse.xtext.generator.trace.AbstractStatefulTraceRegion.<init>(AbstractStatefulTraceRegion.java:36)
	at org.eclipse.xtext.generator.trace.TraceRegion.<init>(TraceRegion.java:58)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer$IdentityStrategy.createRegion(TraceRegionSerializer.java:63)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer$IdentityStrategy.createRegion(TraceRegionSerializer.java:53)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer.doReadFrom(TraceRegionSerializer.java:334)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer.doReadFrom(TraceRegionSerializer.java:337)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer.doReadFrom(TraceRegionSerializer.java:285)
	at org.eclipse.xtext.generator.trace.TraceRegionSerializer.readTraceRegionFrom(TraceRegionSerializer.java:169)
	at org.eclipse.xtext.generator.trace.internal.AbstractTraceForURIProvider$CachedTraces.getTraceRegion(AbstractTraceForURIProvider.java:125)
	at org.eclipse.xtext.generator.trace.internal.AbstractTraceForURIProvider$1.getTraceRegion(AbstractTraceForURIProvider.java:208)
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace.doGetRootTraceRegion(AbstractTrace.java:126)
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace.getRootTraceRegion(AbstractTrace.java:102)
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace.hasTraceData(AbstractTrace.java:109)
	at org.eclipse.xtext.ui.generator.trace.TraceBasedOpenerContributor.collectSourceFileOpeners(TraceBasedOpenerContributor.java:75)
	at org.eclipse.xtext.ui.generator.trace.TraceOrMarkerBasedOpenerContributor.collectSourceFileOpeners(TraceOrMarkerBasedOpenerContributor.java:35)
	at org.eclipse.xtext.ui.shared.internal.OpenSourceFilePropertyTester.canOpenSourceFile(OpenSourceFilePropertyTester.java:43)
	at org.eclipse.xtext.ui.shared.internal.OpenSourceFilePropertyTester.test(OpenSourceFilePropertyTester.java:59)
	at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
	at org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:100)
	at org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:51)
	at org.eclipse.core.internal.expressions.WithExpression.evaluate(WithExpression.java:75)
	at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.isCoreExpressionVisible(ContributionsAnalyzer.java:285)
	at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.isVisible(ContributionsAnalyzer.java:259)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.computeVisibility(ContributionRecord.java:167)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java:98)
	at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:191)
	at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:202)
	at org.eclipse.ui.internal.WorkbenchWindow$8.run(WorkbenchWindow.java:704)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:37)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4213)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3820)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1044)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
So now the question is how did I end up generated bad traces.
Thanks so much for your help
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777104 is a reply to message #1777102] Fri, 24 November 2017 08:03 Go to previous messageGo to next message
and org.eclipse.xtext.builder.EclipseResourceFileSystemAccess2.flushSourceTraces(String)
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777105 is a reply to message #1777104] Fri, 24 November 2017 08:10 Go to previous messageGo to next message
can you try to add
def Class<? extends EclipseSourceFolderProvider> bindEclipseSourceFolderProvider() {
return JDTAwareSourceFolderProvider;
to the ui module?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777120 is a reply to message #1777105] Fri, 24 November 2017 12:30 Go to previous messageGo to next message
So in the method flushSourceTraces(String generatorName), sourceFile is set to the correct file name but the like sourceFile.exists() returns false. Strange the file exists.
Do you still want me to add JDTAwareSourceFolderProvider?
Does the error message about the inconsistent region ring a bell?
thanks
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777121 is a reply to message #1777120] Fri, 24 November 2017 12:45 Go to previous messageGo to next message
yes. if i do so the open gnerated file finds trace files.
am not sure about the inconsisten message. i test only with a hello world example. but yes that might be an issue?
on which os are you?
there is TraceAwarePostProcessor / LineSeparatorHarmonizer as well which might be relevant to bind on windows.
please test this with minimal possible traces.
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777122 is a reply to message #1777121] Fri, 24 November 2017 12:52 Go to previous messageGo to next message
=> try
def Class<? extends LineSeparatorHarmonizer> bindLineSeparatorHarmonizer() {
TraceAwarePostProcessor;
as well
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777123 is a reply to message #1777122] Fri, 24 November 2017 12:57 Go to previous messageGo to next message
and yes sourceFile.exists()
is caused by JDTAwareSourceFolderProvider
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777141 is a reply to message #1777123] Fri, 24 November 2017 17:27 Go to previous messageGo to next message
I did add both
in the RuntimeModule and
in the UIModule but the problem remains.
I also reduced the DSL file to the bare miinimum and I still have that error
!STACK 0
  LocationData [TextRegionWithLineInformation [72:54][lineNumber=5, endLineNumber=7]][path=Forex-1.0.0.wkfs]
} nestedRegions={
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace$3.iterator(AbstractTrace.java:460)
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace$1$1.<init>(AbstractTrace.java:368)
	at org.eclipse.xtext.generator.trace.internal.AbstractTrace$1.iterator(AbstractTrace.java:366)
	at org.eclipse.xtext.common.types.shared.jdt38.OriginalEditorSelector.getXtextEditor(OriginalEditorSelector.java:162)
	at org.eclipse.xtext.common.types.shared.jdt38.OriginalEditorSelector.findXbaseEditor(OriginalEditorSelector.java:154)
	at org.eclipse.xtext.common.types.shared.jdt38.OriginalEditorSelector.overrideEditors(OriginalEditorSelector.java:71)
	at org.eclipse.ui.ide.IDE.overrideEditorAssociations(IDE.java:937)
I enabled the traces just by replacing
		fsa.generateFile(
			function.
				toClassFileName,   getFunctionStructure(function, context))
by
		fsa.generateTracedFile(
			function.
				toClassFileName, function,  getFunctionStructure(function, context))
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777154 is a reply to message #1777141] Sat, 25 November 2017 02:55 Go to previous messageGo to next message
Can you please share a complete sample project so that I can reproduce this.
And are you on windows or are you not
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777155 is a reply to message #1777154] Sat, 25 November 2017 03:35 Go to previous messageGo to next message
yes on windows, I will try to build a sample.
Did some more investigation and it seems that the problem is that on the following line:
if (parent.getMyOffset() + parent.getMyLength() < getMyOffset() + getMyLength())
	return false;
the line
parent.getMyOffset() + parent.getMyLength()  = 457
whereas
getMyOffset() + getMyLength() = 460
I understand from your question that you think of a carriage return problem or something of the sort.
The problem with that theory is that I have 26 lines and the difference should be higher. And indeed looking at the generated files:
the actual length is : 26 lines and 482 characters with lines ending with CR/LF
This is however in line with 457 (from the trace My end offset field) + 25 (CR)
So I think the CRLF does explain the missing 25 characters (do not have CRLF on the last line) but the +3 characters mentionned previously.
[Updated on: Sat, 25 November 2017 04:03] by Moderator
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777160 is a reply to message #1777155] Sat, 25 November 2017 04:02 Go to previous messageGo to next message
yes this is why i need something i can debug
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777162 is a reply to message #1777160] Sat, 25 November 2017 04:11 Go to previous messageGo to next message
i tried my example in a windows vm and dont get the error.
so it must have something todo with the structure of your generator
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777790 is a reply to message #1777162] Mon, 04 December 2017 11:18 Go to previous messageGo to next message
sorry for the late answer but I was not able to work on this project for a solid week.
So I reduced the code generation to the bare mimimum and it did work.
Now I am re-emabling step by step code generation.
I get a lot of "Type mismatch: cannot convert from IGeneratorNode to StringConcatenationClient"
What I do not get is that I explicit set the return type:
	@Traced def dispatch StringConcatenationClient  generatePath(ValueExpression root, Column target, Key key,  GeneratorContext context) {
        if (root instanceof LookupExpression) {
            generatePathForLookup(root as LookupExpression, target, key, context)
@Traced def StringConcatenationClient  generatePathForLookup(LookupExpression root, Column target, Key key,  GeneratorContext context) {
	    val targetType = DatamodelTypeProvider.typeFor(target)
        switch (targetType.class) {
Any idea?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777792 is a reply to message #1777790] Mon, 04 December 2017 11:22 Go to previous messageGo to next message
xtend implentation logic => cannot answer/have no idea. the type inference is not as powerful as it should be
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777794 is a reply to message #1777792] Mon, 04 December 2017 11:41 Go to previous messageGo to next message
=> i think @traced is not meant to be split up with explicit return type
this active annotation does some fiddeling around with methods and bodys so i will break
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777795 is a reply to message #1777794] Mon, 04 December 2017 11:43 Go to previous messageGo to next message
potential workaround:
really create the client
@Traced def dispatch generatePath(Model root, GeneratorContext context) {
return '''«generatePathForLookup(root,context)»'''
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777810 is a reply to message #1777795] Mon, 04 December 2017 14:15 Go to previous messageGo to next message
Thanks Cristian,
it did the trick and the tracing seems to be working correctly. At least the cursor positioning is correct.
Thank you so much. No I will try to see what can be done from a debugger perspective.
Any news on this blog post of yours?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777817 is a reply to message #1777810] Mon, 04 December 2017 14:48 Go to previous messageGo to next message
yes as posted in other thread its here https://blogs.itemis.com/en/debugging-dsls-in-xtext-and-eclipse
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777820 is a reply to message #1777817] Mon, 04 December 2017 15:13 Go to previous messageGo to next message
Ok thanks,
just tested it and while I did got any error and the Toggle breakpoint menu appears. The breakpoint is not actually created. I did check the getAdapter and the getClassNamePattern.
Do you prefer me to start a new thread to discuss it?
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777821 is a reply to message #1777820] Mon, 04 December 2017 15:22 Go to previous messageGo to next message
Yes.
Re: How to extend OpenGeneratedFileHandler to position the cursor in the right region [message #1777822 is a reply to message #1777821] Mon, 04 December 2017 16:05 Go to previous message
And you should debug the code
Previous Topic:Xbase: Fields in generated inner class not recognized, no problems as class in own file
Next Topic:Accessing Code behind Model
Current Time: Sat Jul 26 12:00:31 EDT 2025
Powered by FUDForum. Page generated in 0.11307 seconds
