Home » Modeling » Papyrus » Some questions on styles and css
Some questions on styles and css [message #1776787] Tue, 21 November 2017 10:55 Go to next message
Hi!
I'm trying to style my stereotyped elements and have some questions.
1. How can I make the border of a shape dashed?
2. Show the packagedElements compartment using css?
I can show the symbol compartment using:
Component >  Compartment[type="compartment_shape_display"]
but what is the type (string) for the packagedElements compartment? I've tried 'compartment_packagedElements' but couldn't make it work.
3. Is is possible to set the initial size of elements using CSS?
Re: Some questions on styles and css [message #1776794 is a reply to message #1776787] Tue, 21 November 2017 11:38 Go to previous messageGo to next message
Hi Patrik,
1. borderStyle: dashed;
You may also use 'custom' instead of 'dashed', then specify a customDash: int[] property:
borderStyle: custom;
customDash: 5 3 1 2 8 6;
(Where each odd number is a dash length, and each even number is the space between two dashes)
2. Compartment[kind=packagedElements]
type corresponds to the (internal) serialization type (That you can find in the *.notation file when reading it with a text editor). kind is a human-readable alternative that is mapped to (most) types, to present them in a more consistent way. For compartments, the kind should correspond to the title of the compartment, in camelCase. So you should use [kind=symbol] as well (Instead of type="compartment_shape_display")
3. It has been done in some projects, but I think the layout constraints were hard-coded (Rather than CSS-based). In Papyrus, the default sizes are defined in the Diagram model then generated in Java, so I don't think it's possible to customize them with CSS.
HTH,
Camille
Re: Some questions on styles and css [message #1776807 is a reply to message #1776794] Tue, 21 November 2017 14:39 Go to previous messageGo to next message
Thanks Camille
Re: Some questions on styles and css [message #1776830 is a reply to message #1776794] Wed, 22 November 2017 02:35 Go to previous messageGo to next message
Camille Letavernier wrote on Tue, 21 November 2017 17:38
Hi Patrik,
Actually, I can't get this to work, Compartment[type=symbol] doesn't work for me.
Also, looking at the notation file doesn't make it clearer for me. I guess the serialization type is the type attribute? I've tried that and it doesn't work either. I've attached the notation file.
Patrik
Re: Some questions on styles and css [message #1776835 is a reply to message #1776830] Wed, 22 November 2017 02:59 Go to previous messageGo to next message
Hi Patrik,
You should use "kind", not "type", i.e. either:
Compartment[kind=symbol]
or
Compartment[type=compartment_shape_display]
I believe custom compartments (Like Shape or Stereotype) are not serialized by default, as they are provided by an extension of the diagram, and not explicitly part of the diagram. For other compartments (Like Package Structure, Class attributes, etc.), you can either use the kind + title (e.g. Compartment[kind=attributes]) or the type + notation type (e.g. Compartment[type=Component_PackagedElementShape]). I simply recommend using the kind + title approach, which IMO is more consistent and easier to remember, but both should work.
Camille
Re: Some questions on styles and css [message #1776846 is a reply to message #1776835] Wed, 22 November 2017 04:05 Go to previous message
Ah, missed the kind, thanks again.
Previous Topic:Understanding the Architecture Framework
Next Topic:Stereotypes and CSS: can select StereotypeComment on the basis of related stereotype
Current Time: Sun Jul 27 12:50:46 EDT 2025
Powered by FUDForum. Page generated in 0.04862 seconds
