Home » Modeling » TMF (Xtext) » Request Guidance on Best Practice for Parsing/Content Assist
Request Guidance on Best Practice for Parsing/Content Assist [message #1776811] Tue, 21 November 2017 15:36 Go to next message
What is the best practice for dealing with the code snippet below.
Looking for guidance regarding
  • Parsing
  • Content Assist
Based on the responses I should be able to figure out ( but pointer would be appreciated)
  • Validation
  • QuickFix
  • Value Converter (if required)
KeywordDATE: {KeywordDATFMT}
	'DATE' ('('
		//2-Digit Year Formats
		(format='*MDY' separator=('/'|'-'|'.'|','|'&')?)  |
		(format='*DMY' separator=('/'|'-'|'.'|','|'&')?)  |
		(format='*YMD' separator=('/'|'-'|'.'|','|'&')?)  |
		(format='*JUL' separator=('/'|'-'|'.'|','|'&')?)  |
		//4-Digit Year Formats
		(format='*ISO' separator=('-')?) |
		(format='*USA' separator=('/')?) |
		(format='*EUR' separator=('.')?) |
		(format='*JIS' separator=('-')?)
KeywordTIME: {KeywordTIME}
	'TIME' ('('
		(format='*HMS' separator=(':'|'.'|','|'&')?) |
		(format='*ISO' separator=('.')?)             |
		(format='*USA' separator=(':')?)             |
		(format='*JIS' separator=(':')?)
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776812 is a reply to message #1776811] Tue, 21 November 2017 15:39 Go to previous messageGo to next message
Hmmm I don't really get your question. Can you please be more specific
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776890 is a reply to message #1776812] Wed, 22 November 2017 09:49 Go to previous messageGo to next message
@Christian,
The refactored the snippet (see below) has 2 issues
1) The Content Assist does not recommend either the DATSEP or the TIMSEP as options
2) The .mwe2 workflow gives the following error message :
error(208): ../bz.erasmus.x400.xrpgle.xtext/src-gen/bz/erasmus/x400/xrpgle/xtext/parser/antlr/lexer/InternalXRPGLELexer.g:74:1: The following token definitions can never be matched because prior tokens match the same input: RULE_TIMSEP
error(208): ../bz.erasmus.x400.xrpgle.xtext.ide/src-gen/bz/erasmus/x400/xrpgle/xtext/ide/contentassist/antlr/lexer/InternalXRPGLELexer.g:74:1: The following token definitions can never be matched because prior tokens match the same input: RULE_TIMSEP
My question:
What is most "correct" way of dealing with the grammar rule?
The Refactored Code Snippet:
KeywordDATE: {KeywordDATE}
	'DATE' ('(' format=DATFMT (separator=DATSEP)? ')')?
enum DATFMT:
	MDY = '*MDY' |
	DMY = '*DMY' |
	YMD = '*YMD' |
	JUL = '*JUL' |
	ISO = '*ISO' |
	USA = '*USA' |
	EUR = '*EUR' |
	JIS = '*JIS'
terminal DATSEP returns ecore::EChar:
	'TIME' ('(' format=TIMFMT (separator=TIMSEP)? ')')?
enum TIMFMT:
	HMS = '*HMS' |
	ISO = '*ISO' |
	USA = '*USA' |
	EUR = '*EUR' |
	JIS = '*JIS'
terminal TIMSEP returns ecore::EChar:
[Updated on: Wed, 22 November 2017 09:51] by Moderator
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776899 is a reply to message #1776890] Wed, 22 November 2017 10:23 Go to previous messageGo to next message
this error says your grammar is ambious. there is no general solutiion to this since it depends on the individual case. so a best practice is the wrong thing to ask for. your original snippet did no even contain TIMSEP
but having the same stuff as keywords and as terminals wont work. thus your solution seems legit (grammar snippets quite incomplete)
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776909 is a reply to message #1776899] Wed, 22 November 2017 12:02 Go to previous messageGo to next message
@Christian,
The ambiguity is caused when DATFMT and TIMFMT is defined together (refer option2 in the grammar below).
Your previous post, confused me a bit. Do you recommend option1 or option2 or maybe a different approach?
My end-goal is to parse the "Date Keyword" from the RPGLE language, but I am struggling with the translation of the info on IBM's knowledge center into xtext grammer.
Links to the Knowledge center:
* Date Keyword - Parsing
* Date Data Type - Validation
More complete grammer
Model:
variabledeclarations+=StandAloneField
StandAloneField:
	'DCL-S' name=ID type=DataType keywords+=StandAloneFieldKeywords* (';')?
StandAloneFieldKeywords:
	placeholder= 'StandAloneFieldKeywords'
DataType:
//	CharacterDataType	|
//	NumericDataType		|
	DateTimeDataType
DateTimeDataType:
//	KeywordTIMESTAMP |
//	KeywordTIME      |
	KeywordDATE
// Option 1:
	'DATE' ('('
	'TIME' ('('
// Option2:
enum DATFMT:
	ISO = '*ISO' |
	MDY = '*MDY' |
	DMY = '*DMY' |
	YMD = '*YMD' |
	JUL = '*JUL' |
	USA = '*USA' |
	EUR = '*EUR' |
	JIS = '*JIS'
enum TIMFMT:
	ISO = '*ISO' |
	HMS = '*HMS' |
	USA = '*USA' |
	EUR = '*EUR' |
	JIS = '*JIS'
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776910 is a reply to message #1776909] Wed, 22 November 2017 12:40 Go to previous messageGo to next message
id prefer option 2, maybe replaced by a datatype rule (+ custom content assist) e.g.
// no terminal keyword
Re: Request Guidance on Best Practice for Parsing/Content Assist [message #1776920 is a reply to message #1776811] Wed, 22 November 2017 14:51 Go to previous message
Thanks for the guidance.
Will give Option2 a shot.
Previous Topic:Error: Cyclic resolution of lazy links
Next Topic:Remove warning/error marker
Current Time: Sun Jul 27 09:22:16 EDT 2025
Powered by FUDForum. Page generated in 0.06446 seconds
