Home » Modeling » TMF (Xtext) » Xtext web editor is disabled(The Xtext web editor for the default Xtext project is not responding, that is, it does not allow writing text.)
Xtext web editor is disabled [message #1776728] Mon, 20 November 2017 15:02 Go to next message
I am just starting the Xtext web-based editor. I created an Xtext project with Web Integration checked and Preferred Build System Maven. I also checked Create Update Site . Once the projects are generated, I generated the Xtext Artifacts before I run the Maven install command. The build process went successful. I opened the index.html , however, the web editor is disabled in other words, i cannot write text inside the editor, even if the web page seems to be correctly displayed.
Please help, thank you,
//Nas
  • Attachment: Capture.PNG
    (Size: 5.74KB, Downloaded 93 times)
Re: Xtext web editor is disabled [message #1776730 is a reply to message #1776728] Mon, 20 November 2017 15:05 Go to previous messageGo to next message
Can you share the complete example project.
Diagnosing from screenshot is hard
And what do you mean by open index html
You usually call a maven command or a Java. Aim that starts a server
(There should be a runserver launcher or something like that in the project)
[Updated on: Mon, 20 November 2017 15:09] by Moderator
Re: Xtext web editor is disabled [message #1776732 is a reply to message #1776730] Mon, 20 November 2017 15:49 Go to previous message
That is right Christian, I had to run the launcher first. It is working :)
Best,
//Nas
Previous Topic:Debugging DSL Instances
Next Topic:Content Assist in Web Editor
Current Time: Sun Jul 27 04:11:52 EDT 2025
Powered by FUDForum. Page generated in 0.05894 seconds
