How to create a Device to use in the 4DIAC IDE [message #1776547] |
Fri, 17 November 2017 09:56  |
I have a number of years of experience in programming and commissioning automation solutions and systems. I am very interested in using 4DIAC and forte in future projects, and would like to know the process for creating your own devices to use in the IDE. By this I am referring to what many would call legacy PLC's such as, but not limited to , Omron CP series, Siemens S5 series, Allen-Bradley SLC series (100 and 500), etc... When I look at the documentation I cannot find anything to point me to the answer, and a review of the xml files for existing devices does not seem to help. I would assume there is some layer of the API I am not seeing with respect to device creation.
Re: How to create a Device to use in the 4DIAC IDE [message #1776617 is a reply to message #1776614] |
Sat, 18 November 2017 10:20   |
Hello, and thank you for the quick response.
As for specific hardware, a good one in my opinion and also for some of my current solutions I provide would be Rockwell Automation Micro800 series and their associated HMI's the PanelView 800 line. They are purported to be open PLC's, I am sure with a Rockwell twist.
Some of the reasoning behind my question was to eventually eliminate my windows OS based PC's needs in my chosen line of work, which I will very likely retire from before I accomplish that.
Is there a template available for making a device in (I assume FORTE) where I could attempt to build the ones I need as I need them? Is it the same as making an Eclipse Plugin? I have access to hardware usually fairly readily, and in most instances can get a good amount of technical information from the OEM. I would of course freely release it back to the community, in case someone else ran into the same need.
A number of years back, I was working as a contractor at a large automation system integrator, they had developed a C program that would write pallet traffic PLC code for the Siemens S5 PLC, as Function Blocks of statement list.
[Updated on: Sat, 18 November 2017 10:38] by Moderator
FUDForum. Page generated in 0.03895 seconds
