Home » Eclipse Projects » Sirius » Diagram extension question
Diagram extension question [message #1776542] Fri, 17 November 2017 08:59 Go to next message
Hello there,
I'm developing a GEMOC solution for a DSL. The GEMOC part is already done and it works pretty good, but I have some questions about Sirius diagram extension mechanism.
The background:
I have a completely functional language, let's call it language A, with Sirius diagrams working pretty good. I needed to extend the metamodel elements to include some properties I will use for GEMOC (the GEMOC part is not important, just giving the context). GEMOC generates the extended language model, classes and adapters, so I have a second language (extended A) also completely functional in terms of metamodeling.
The fact is that I want to define an diagram extension for this extended A, that will (of course) extends the existing diagram definition of language A. In this first moment, I just want to change the color of element borders if a boolean property (hasChanged) is true.
I created, therefore, a new viewpoints specification file (.odesign) with a new viewpoint I called ExtendedA. This viewpoint contains a single element: a diagram extension. That extends an ActivityDiagram present in language A.
This extension contains a single layer, I named it Debug. Debug has a single element: a style customization. The predicate expression is [self.hasChanded/], since it will trigger when the boolean property hasChanged is true.
The style customization also have a single element: a property customization (by selection). Follows a print with the definition of this property customization.
index.php/fa/31305/0/
The issue is that the "value selection" field appears empty, and it is always empty. I tried a lot of things but nothing worked. I created a new UserDefinedColor DebugColor and want to use it as the value of borderColor, but the value never appears here.
index.php/fa/31306/0/
It is worth highlighting that not every element have this property (hasChanged), just a few. However, Sirius should ignore everyone that doesnt match it, right?
What am I missing?
@edit
I'm using Sirius 5.0.2
  • Attachment: sirius1.png
    (Size: 18.39KB, Downloaded 708 times)
  • Attachment: sirius2.png
    (Size: 6.38KB, Downloaded 608 times)
[Updated on: Fri, 17 November 2017 09:01] by Moderator
Re: Diagram extension question [message #1776545 is a reply to message #1776542] Fri, 17 November 2017 09:40 Go to previous messageGo to next message
Based on the screenshot, you have added a "User Color Palette" named DebugColor, but you have not defined a color inside it. In your property extension, it is a color that is expected not a palette.
Steve
Re: Diagram extension question [message #1776546 is a reply to message #1776545] Fri, 17 November 2017 09:41 Go to previous messageGo to next message
By the way, there are different kind of colors that can be added to a "User Color Palette". You can find more information about it here: https://www.eclipse.org/sirius/doc/specifier/general/Colors.html
Re: Diagram extension question [message #1776548 is a reply to message #1776546] Fri, 17 November 2017 09:59 Go to previous messageGo to next message
Hello Steve,
Oh, I cut off the part of the screenshot that shows the arrow to expand the defined User Colors. But there is one.
@edit
index.php/fa/31307/0/
  • Attachment: sirius3.png
    (Size: 1.40KB, Downloaded 502 times)
[Updated on: Fri, 17 November 2017 10:02] by Moderator
Re: Diagram extension question [message #1776553 is a reply to message #1776548] Fri, 17 November 2017 11:12 Go to previous messageGo to next message
Ok ok that was too simple.
I tested with a sample and it seems that we have a bug. When the "apply on all" checkbox is checked...the value selection list is empty/blank. Can you try to uncheck the checkbox, then select your color and then check it again? With my sample I end up with the wanted result (despite the extra steps) and the serialisation of the odesign file is OK.
Can you create a bugzilla on this issue please?
Steve
Re: Diagram extension question [message #1776558 is a reply to message #1776553] Fri, 17 November 2017 12:13 Go to previous messageGo to next message
Hello Steve,
I tried that, still empty. I managed to add the value manually (editing the file as text), but apparently is not working. Is the property name borderColor correct? I'm pretty sure that I'm setting the wrong property. I saw in an example but can be outdated. Will try to change the color of the element, instead of the border.
Re: Diagram extension question [message #1776717 is a reply to message #1776558] Mon, 20 November 2017 12:31 Go to previous message
Yes the property is named "borderColor". You need to select the a style to have the auto-completion if I remember correctly. When I tested it provided me with the choices color, labelColor and borderColor.
Steve
Previous Topic:Two different representations of the same relationship
Next Topic:Evaluating "If" condition in Acceleo/Sirius
Current Time: Fri Jul 25 10:27:02 EDT 2025
Powered by FUDForum. Page generated in 1.09856 seconds
