My RCP does not detect updates from my update site [message #1776464] |
Thu, 16 November 2017 11:03  |
I created and update site.
I deleted all files:
- plugins/*
- features/*
- artifacts.jar
- content.jar
- logs.zip
I don't know why there are so many files generated?
The Rebuild and Rebuild all has for me a strange behavior.
Rebuild all should delete everything, and regenerate everything from the site.xml.
Instead of that I have a mix between old stuffs and new stuffs.
Anyway, I deleted all files above and rebuild all.
I have one feature including one plugin.
I changed some code in my plugin.
Increase the plugin version to 1.0.1
Increase the feature version to 1.0.1
My RCP contains the version 1.0.0 of my feature.
When I use check for updates in my RCP, "no updates were found"
When I install a new software, in the content of the repository I can select my 1.0.1 feature, but the error comes after the next button:
"Your original request has been modified.
"Sales - Quoting - Data" is already installed, so an update will be performed instead.
Cannot complete the install because of a conflicting dependency."
So no update is possible and no installation?
I want to fix the update search because I would like to put an automatic update to my RCP at startup.
Why my RCP does not detect the update version from my repository?
What is my mistake?
FUDForum. Page generated in 0.03048 seconds
