Home » Newcomers » Newcomers » neon.3 does not start(error occurred read metadata\log)
neon.3 does not start [message #1776431] Thu, 16 November 2017 07:22 Go to next message
Hey guys,
i tried to use eclipse for university on my notebook but everytime i try to start it i get an error message instead. (error uploaded as image)
I never had any kind of programming tool on this notebook before and tried as much as i could from google
i tired to delete metadata, i tried to clear the cache i tried to use diffrent workspaces.
in another forum i found a post about deleting the .snap files. I can't find these files on my notebook. And if it is correct what i raed, the .snap files are created during the work with eclipse to prevent a loss of progress in case the programm or pc crashes. No suprise i cant delete files which can't be created due to the fact that i can't use eclpise.
i hope these informations are enough to find the problem, if not just ask and i will try my best to awnser them.
Re: neon.3 does not start [message #1776434 is a reply to message #1776431] Thu, 16 November 2017 07:39 Go to previous messageGo to next message
What's in the log file that the error message mentions?
Re: neon.3 does not start [message #1776439 is a reply to message #1776434] Thu, 16 November 2017 08:05 Go to previous messageGo to next message
!SESSION 2017-11-16 12:21:53.333 -----------------------------------------------
eclipse.buildId=4.6.3.M20170301-0400
java.version=9.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:22:05.327
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
... 23 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:22:05.360
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
... 21 more
!SESSION 2017-11-16 12:23:28.550 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:23:39.483
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:23:39.504
!STACK 0
... 21 more
!SESSION 2017-11-16 12:24:00.638 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:24:03.683
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:24:03.704
!STACK 0
... 21 more
!SESSION 2017-11-16 12:26:43.831 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:26:48.053
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:26:48.082
!STACK 0
... 21 more
!SESSION 2017-11-16 12:31:35.883 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:31:43.023
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:31:43.056
!STACK 0
... 21 more
!SESSION 2017-11-16 12:39:04.155 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:39:08.890
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:39:08.912
!STACK 0
... 21 more
!SESSION 2017-11-16 12:43:39.761 -----------------------------------------------
java.version=9.0.1
!ENTRY org.eclipse.osgi 4 0 2017-11-16 12:43:44.040
!STACK 1
... 23 more
... 25 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2017-11-16 12:43:44.060
!STACK 0
... 21 more
this is what the log says but i dont have any clue what this means
Re: neon.3 does not start [message #1776456 is a reply to message #1776439] Thu, 16 November 2017 09:47 Go to previous messageGo to next message
Better would be to install the latest Oxygen. Failing that, you'll have to follow these instructions to get older versions of Eclipse to work with Java 9: https://wiki.eclipse.org/Configure_Eclipse_for_Java_9
Re: neon.3 does not start [message #1776466 is a reply to message #1776456] Thu, 16 November 2017 11:05 Go to previous messageGo to next message
well, thanks. oxygen worked on the first try.
Re: neon.3 does not start [message #1781827 is a reply to message #1776439] Tue, 13 February 2018 11:16 Go to previous message
If you're not in the mood to upgrade (as some of us aren't) you can simply specify the java8 jdk by updating the eclipse.ini file with the -vm parameter and full path to a Java 8 or earlier VM. This error occurred, most likely, because you're using Java9
Previous Topic:Content Assist for SAPUI5 - Eclipse Neon.3
Next Topic:My Eclipse won't run
Current Time: Sun Jul 27 13:56:12 EDT 2025
Powered by FUDForum. Page generated in 0.12878 seconds
