Home » Eclipse Projects » Kura » Helloworld(Nt able to run Hello world example bundle in target device)
Helloworld [message #1775679] Fri, 03 November 2017 05:36 Go to next message
Im able to build helloworld bundle and deploy it in target in which kura 2.1.0 is running .In target helloworld bundle is installed but when i tried to make it start it throws below error
gogo: BundleException: The bundle "org.eclipse.kura.example.hello_1.0.0.201711031141 [79]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: JavaSE-1.8
Target device java version is "1.8.0_151"
can any one help me out.
khaleel
Re: Helloworld [message #1775715 is a reply to message #1775679] Fri, 03 November 2017 16:17 Go to previous messageGo to next message
In the helloworld bundle, please update the MANIFEST.MF file and either remove the line "Bundle-RequiredExecutionEnvironment: JavaSE-1.8" or update the line to match the Java version you are running on the target device.
--Dave
Re: Helloworld [message #1775850 is a reply to message #1775715] Tue, 07 November 2017 04:12 Go to previous messageGo to next message
Thanks for reply
I have deleted "Bundle-RequiredExecutionEnvironment: JavaSE-1.8" from MANIFEST.MF file and then i got the below error
osgi>
!ENTRY 1 0 2017-11-07 09:03:29.276
!MESSAGE [IAgent][RemoteBundleAdminImpl@1f6428a] [startBundle] Bundle cannot be started: Error[code=-6000;message=Failed to start bundle: The bundle "org.eclipse.kura.example.hello_osgi_1.0.0.201711071225 [79]" could not be resolved. Reason: Missing Constraint: Import-Package: org.osgi.service.component; version="1.2.2";details=null]
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.kura.example.hello_osgi_1.0.0.201711071225 [79]" could not be resolved. Reason: Missing Constraint: Import-Package: org.osgi.service.component; version="1.2.2"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.tigris.mtoolkit.iagent.internal.rpc.RemoteBundleAdminImpl.startBundle(RemoteBundleAdminImpl.java:230)
at org.tigris.mtoolkit.iagent.internal.pmp.InvocationThread.run(InvocationThread.java:54)
at org.tigris.mtoolkit.iagent.internal.utils.ThreadPool$Worker.run(ThreadPool.java:179)
at java.lang.Thread.run(Thread.java:748)
This is my manifest file
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Hello Example
Bundle-SymbolicName: org.eclipse.kura.example.hello_osgi
Bundle-Version: 1.0.0.qualifier
Service-Component: OSGI-INF/*.xml,
 component.xml
Import-Package: org.eclipse.osgi.framework.console;version="1.0.0",
 org.osgi.framework;version="1.3.0",
 org.osgi.service.component;version="1.2.2",
 org.osgi.service.component.annotations;version="1.2.0";resolution:=optional,
 org.osgi.util.tracker;version="1.3.1",
 org.slf4j;version="1.7.21"
when I change org.osgi.service.component;version="1.2.2" to 1.2.0 then no error is getting.
Is it ok to change it manually ?
Re: Helloworld [message #1775900 is a reply to message #1775850] Tue, 07 November 2017 19:57 Go to previous messageGo to next message
Yes, that is fine. But it sounds like the target platform you are using to create the hello world application is different than the Kura version running on your Raspberry Pi. You should make sure you are using the user workspace that matches the Kura version on your Pi.
Re: Helloworld [message #1776006 is a reply to message #1775900] Thu, 09 November 2017 02:34 Go to previous messageGo to next message
Yes thats the issue version mismatch.I have changed my target version now im able to deploy and run the bundle in target.
Thanks for support
Facing issue to deploy .dp file to kura [message #1776427 is a reply to message #1775900] Thu, 16 November 2017 06:29 Go to previous message
I am implementing simple block reactive and want deploy package in kura. But every time I am uploading .dp file kura stops working or file not install. Also I followed all steps to configure eclipse and kura. Like importing zip for block reactive , installed mtoolkit. In kura I did all network setup but still facing issue.
THIS IS THE OUTPUT OF /var/log/kura-console.log
!MESSAGE Bundle 'com.bitreactive.blocks.osgi.runtime/2.6.1 already present in other deployment packages!
!ENTRY 1 0 2017-11-16 03:43:10.582 !MESSAGE [IAgent][DeploymentEventListener@49dc62] [handleComplete] Deployment package event is not successful
!ENTRY org.apache.felix.deploymentadmin 4 0 2017-11-16 03:48:25.393 !MESSAGE Bundle 'com.bitreactive.blocks.osgi.runtime/2.6.1 already present in other deployment packages!
!ENTRY 1 0 2017-11-16 03:48:25.402 !MESSAGE [IAgent][DeploymentEventListener@49dc62] [handleComplete] Deployment package event is not successful
THIS IS THE OUTPUT OF 'ss' command
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.1.v20120830-144521 Fragments=74
1 ACTIVE com.bitreactive.library.coap_1.5.0
2 INSTALLED jdk.dio_1.0.5
3 ACTIVE org.eclipse.kura.emulator.clock_1.0.1
4 ACTIVE com.bitreactive.library.buffering_3.11.2
5 ACTIVE org.eclipse.kura.camel.xml_1.0.0
6 ACTIVE com.google.protobuf_2.6.0
7 ACTIVE org.eclipse.kura.core.net_1.0.10
8 ACTIVE org.eclipse.kura.example.camel.publisher_1.0.0
9 ACTIVE com.bitreactive.library.polling_1.1.2
10 ACTIVE org.eclipse.kura.example.camel.quickstart_1.1.0
11 ACTIVE org.eclipse.equinox.util_1.0.400.v20120522-2049
12 ACTIVE org.eclipse.osgi.util_3.2.300.v20120522-1822
13 ACTIVE com.bitreactive.library.geofence_1.5.0
14 ACTIVE org.apache.felix.dependencymanager_3.0.0
15 ACTIVE org.eclipse.soda.dk.comm_1.2.3
16 ACTIVE com.bitreactive.library.rpi.peripherals_1.15.0
17 ACTIVE org.eclipse.jetty.http_8.1.3.v20120522
18 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
19 ACTIVE californium-osgi_1.0.0.SNAPSHOT
20 ACTIVE com.bitreactive.library.osgi.service_1.0.0
21 ACTIVE org.eclipse.kura.emulator_1.0.8
22 ACTIVE com.google.gson_2.2.4
23 ACTIVE org.apache.camel.camel-kura_2.17.2
24 ACTIVE org.hsqldb.hsqldb_2.3.0
25 ACTIVE com.bitreactive.library.keyteq.sms_1.1.0
26 ACTIVE com.bitreactive.library.chirp_2.0.0
27 ACTIVE org.eclipse.kura.deployment.agent_1.0.7
28 ACTIVE org.eclipse.equinox.common_3.6.100.v20120522-1841
29 ACTIVE org.eclipse.jetty.continuation_8.1.3.v20120522
30 ACTIVE org.eclipse.jetty.server_8.1.3.v20120522
31 ACTIVE org.eclipse.jetty.util_8.1.3.v20120522
32 ACTIVE org.eclipse.kura.core.configuration_1.0.9
33 ACTIVE com.bitreactive.library.properties_1.2.0
34 ACTIVE org.apache.camel.camel-core_2.17.2
Fragments=54
35 ACTIVE org.eclipse.equinox.event_1.2.200.v20120522-2049
ID State Component Name Located in bundle
1 Active org.eclipse.kura.clock.ClockService org.eclipse.kura.emulator.clock(bid=3)
2 Active org.eclipse.kura.camel.xml.XmlRouterComponent org.eclipse.kura.camel.xml(bid=5)
3 Active org.eclipse.kura.example.camel.publisher.ExamplePublisher org.eclipse.kura.example.camel.publisher(bid=8)
4 Active org.eclipse.kura.example.camel.quickstart.GatewayRouterJava org.eclipse.kura.example.camel.quickstart(bid=10)
5 Unsatisfied org.eclipse.kura.example.camel.quickstart.GatewayRouterXml org.eclipse.kura.example.camel.quickstart(bid=10)
6 Active org.eclipse.kura.emulator.Emulator org.eclipse.kura.emulator(bid=21)
7 Active org.eclipse.kura.deployment.agent org.eclipse.kura.deployment.agent(bid=27)
8 Active org.eclipse.kura.core.configuration.CloudConfigurationHandler org.eclipse.kura.core.configuration(bid=32)
9 Active org.eclipse.kura.configuration.ConfigurationService org.eclipse.kura.core.configuration(bid=32)
10 Active org.eclipse.equinox.event org.eclipse.equinox.event(bid=35)
11 Active org.eclipse.kura.web.Console org.eclipse.kura.web(bid=37)
12 Active org.eclipse.kura.status.CloudConnectionStatusService org.eclipse.kura.core.status(bid=41)
13 Active org.eclipse.kura.core.comm.CommConnectionFactory org.eclipse.kura.core.comm(bid=47)
14 Unsatisfied org.eclipse.kura.example.ble.tisensortag.BluetoothLe org.eclipse.kura.example.ble.tisensortag(bid=73)
15 Unsatisfied org.eclipse.kura.example.publisher.ExamplePublisher org.eclipse.kura.example.publisher(bid=75)
16 Active org.eclipse.kura.certificate.CertificatesService org.eclipse.kura.core.certificates(bid=77)
17 Active org.eclipse.kura.position.PositionService org.eclipse.kura.emulator.position(bid=78)
18 Active org.eclipse.kura.example.camel.aggregation.GatewayRouter org.eclipse.kura.example.camel.aggregation(bid=84)
19 Unsatisfied org.eclipse.kura.camel.KuraCloudComponentResolver org.eclipse.kura.camel(bid=86)
20 Active org.eclipse.kura.watchdog.WatchdogService org.eclipse.kura.emulator.watchdog(bid=87)
21 Unsatisfied org.eclipse.kura.demo.heater.Heater org.eclipse.kura.demo.heater(bid=97)
22 Unsatisfied org.eclipse.kura.data.DataService org.eclipse.kura.core(bid=98)
23 Active org.eclipse.kura.db.DbService org.eclipse.kura.core(bid=98)
24 Unsatisfied org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport org.eclipse.kura.core(bid=98)
25 Active org.eclipse.kura.ssl.SslManagerService org.eclipse.kura.core(bid=98)
26 Active org.eclipse.kura.system.SystemService org.eclipse.kura.core(bid=98)
27 Active org.eclipse.kura.system.SystemAdminService org.eclipse.kura.core(bid=98)
28 Active org.eclipse.kura.crypto.CryptoService org.eclipse.kura.core.crypto(bid=102)
29 Unsatisfied demo1.demo1.Component demo1(bid=110)
30 Unsatisfied org.eclipse.kura.cloud.CloudService org.eclipse.kura.core.cloud(bid=111)
31 Unsatisfied org.eclipse.kura.cloud.CloudCallService org.eclipse.kura.core.cloud(bid=111)
32 Active org.eclipse.kura.core.cloud.factory.DefaultCloudServiceFactory org.eclipse.kura.core.cloud(bid=111)
33 Unsatisfied org.eclipse.kura.cloud.app.command.CommandCloudApp org.eclipse.kura.core.cloud(bid=111)
34 Unsatisfied org.eclipse.kura.camel.cloud.factory.CamelFactory org.eclipse.kura.camel.cloud.factory(bid=116)
35 Active org.eclipse.kura.camel.cloud.factory.CamelCloudServiceFactory org.eclipse.kura.camel.cloud.factory(bid=116)
36 Active org.eclipse.kura.net.NetworkService org.eclipse.kura.emulator.net(bid=120)
37 Active org.eclipse.kura.gpio.GPIOService org.eclipse.kura.emulator.gpio(bid=125)
38 Active org.eclipse.kura.example.beacon.BeaconExample org.eclipse.kura.example.beacon(bid=128)
39 Active org.eclipse.kura.usb.UsbService org.eclipse.kura.emulator.usb(bid=131)
40 Active org.eclipse.kura.bluetooth.BluetoothService org.eclipse.kura.linux.bluetooth(bid=137)
Previous Topic:TCP/IP
Next Topic:Kura Pi 2 Raspberry memory
Current Time: Thu Jul 31 03:14:58 EDT 2025
Powered by FUDForum. Page generated in 0.06639 seconds
