Home » Modeling » TMF (Xtext) » IllegalStateException when formatting
IllegalStateException when formatting [message #1776316] Wed, 15 November 2017 04:37 Go to next message
Im getting following issue:
1927597 [main] ERROR org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork  - Error formatting platform:/resource/de.ubt.ai1.athena.testPluginProject/src/test.athena: null
java.lang.IllegalStateException
	at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.process(NodeModelBasedRegionAccessBuilder.java:229)
	at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.process(NodeModelBasedRegionAccessBuilder.java:220)
	at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.getEObjectToTokensMap(NodeModelBasedRegionAccessBuilder.java:87)
	at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccess.<init>(NodeModelBasedRegionAccess.java:29)
	at org.eclipse.xtext.formatting2.regionaccess.internal.NodeModelBasedRegionAccessBuilder.create(NodeModelBasedRegionAccessBuilder.java:58)
	at org.eclipse.xtext.formatting2.regionaccess.TextRegionAccessBuilder.create(TextRegionAccessBuilder.java:37)
	at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.initRequest(ContentFormatter.java:126)
	at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.exec(ContentFormatter.java:88)
	at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork.exec(ContentFormatter.java:57)
	at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter$FormattingUnitOfWork.exec(ContentFormatter.java:1)
	at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.internalReadOnly(XtextDocument.java:520)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.priorityReadOnly(XtextDocument.java:485)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.priorityReadOnly(XtextDocument.java:142)
	at org.eclipse.xtext.ui.editor.formatting2.ContentFormatter.format(ContentFormatter.java:103)
	at org.eclipse.jface.text.source.SourceViewer.doOperation(SourceViewer.java:992)
	at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1461)
	at org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOperationAction.java:130)
	at org.eclipse.ui.texteditor.TextOperationAction.run(TextOperationAction.java:127)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
	at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:118)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:92)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:305)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:239)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:287)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:527)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:577)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:385)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:331)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:88)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1271)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1078)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1103)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1088)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1130)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1126)
	at org.eclipse.swt.widgets.Widget.wmChar(Widget.java:1547)
	at org.eclipse.swt.widgets.Control.WM_CHAR(Control.java:4962)
	at org.eclipse.swt.widgets.Canvas.WM_CHAR(Canvas.java:364)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4843)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:359)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5178)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2560)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3815)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
when calling the formatter on this code:
type Point : structure {
	attribute x : integer;
	attribute y : integer;
main {
	variable a : integer;
	a <-- 3;
	variable b : integer;
	b <-- a; 	// works fine
	variable p : Point;
	p.x <-- 2; 	// works fine
	p.y <-- a; 	// IllegalStateException
	_output(p);
The formatter works fine except for similar cases like in the code above.
In such cases the execution stops with the error before I even get into the formatter.
Xtend IDE and Xtext Complete SDK are updated to version 2.13.0.v20171020-0920.
The code generation works fine (with traced codegen).
The formatter is the generated stub with some extensions to see if it works:
class AthenaFormatter extends AbstractFormatter2 {
	@Inject extension AthenaGrammarAccess
	def dispatch void format(Program program, extension IFormattableDocument document) {
		// TODO: format HiddenRegions around keywords, attributes, cross references, etc.
		for (TypeDeclaration typeDeclaration : program.getTypeDeclarations()) {
			typeDeclaration.format;
			typeDeclaration.append[setNewLines(2)];
		for (Operation operation : program.getOperations()) {
			operation.format;
			operation.append[setNewLines(2)];
		program.getMainBlock.format;
	def dispatch void format(Enumeration enumeration, extension IFormattableDocument document) {
		for (EnumTypeValue enumTypeValue : enumeration.getValues()) {
			enumTypeValue.format;
	// TODO: implement for Composition, Operation, Block, Return, Conditional, WhileLoop, ForEachLoop, OperationCall, Attribute, Parameter, VariableDeclaration, Assignment, QualifiedAccess, Xor, Or, And, Equality, Comparison, AddSub, MulDiv, Exponent, Cast, ParenthesizedExpression, Not, Reference, ListDeclaration, ListInitRepetition, ListInitRange, ListInitElements
Nikita.
Re: IllegalStateException when formatting [message #1776332 is a reply to message #1776316] Wed, 15 November 2017 07:20 Go to previous messageGo to next message
this sounds like a bug to me. can you open a issue at github.com/eclipse/xtext-core
Re: IllegalStateException when formatting [message #1776344 is a reply to message #1776332] Wed, 15 November 2017 08:57 Go to previous message
Opened an issue:
https://github.com/eclipse/xtext-core/issues/548
Previous Topic:[DELETE PLEASE] Configurable issue code is not registered - check binding for...
Next Topic:Custom validation of constraints from existing metamodel
Current Time: Sat Jul 26 03:42:31 EDT 2025
Powered by FUDForum. Page generated in 0.03564 seconds
