java.lang.NoClassDefFoundError starting Eclipse on Ubuntu 16.04 [message #1776015] |
Thu, 09 November 2017 05:48  |
I just installed Eclipse Oxygen on a fresh Ubuntu 16.04 system. When I run the executable it fails with the following exception:
Exception in thread "logback configurator timer" java.lang.NoClassDefFoundError: ch/qos/logback/core/util/StatusPrinter
at org.eclipse.m2e.logback.configuration.LogPlugin.loadConfiguration(LogPlugin.java:187)
at org.eclipse.m2e.logback.configuration.LogPlugin.configureLogback(LogPlugin.java:144)
at org.eclipse.m2e.logback.configuration.LogPlugin.access$2(LogPlugin.java:107)
at org.eclipse.m2e.logback.configuration.LogPlugin$1.run(LogPlugin.java:62)
at java.base/java.util.TimerThread.mainLoop(Timer.java:556)
at java.base/java.util.TimerThread.run(Timer.java:506)
Caused by: java.lang.ClassNotFoundException: ch.qos.logback.core.util.StatusPrinter cannot be found by org.eclipse.m2e.logback.configuration_1.8.0.20160921-2002
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 6 more
Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged
What is going on here? Do I need to install additional libraries to run Eclipse Oxygen?
Thank you.
FUDForum. Page generated in 0.14789 seconds
