Home » Eclipse Projects » GEF » MidpointLocator problem
MidpointLocator problem [message #177568] Thu, 14 April 2005 11:47 Go to next message
Hi all,
These codes shows a label in the middle of a connection:
Label label=new Label();
label.setText("test");
conn.add(label,new MidpointLocator(conn, 0));
But replace them with following code, nothing is in the middle(expecting an
triangle):
conn.add(new PolygonDecoration(),new MidpointLocator(conn, 0));
why?
Hao
Re: MidpointLocator problem [message #177592 is a reply to message #177568] Thu, 14 April 2005 13:05 Go to previous messageGo to next message
What do you mean nothing? What were you expecting? That triangle is the
polygon decoration you added. Usually, the polygon decorations are used
with endpoint locators to create arrowheads on either end of the connection.
"Hao Zhang" <bjzhanghao@21cn.com> wrote in message
news:d3m3n1$slo$1@news.eclipse.org...
> Hi all,
an
> triangle):
> why?
> Regards
> Hao
Re: MidpointLocator problem [message #177663 is a reply to message #177568] Thu, 14 April 2005 15:28 Go to previous messageGo to next message
A PolygonDecoration is a RotatableDecoration and requires a special locator:
ArrowLocator.
PolygonDecoration is a Polygon. You cannot call setBounds on polygon
either.
> Hi all,
> an
> triangle):
> why?
> Regards
> Hao
Re: MidpointLocator problem [message #177766 is a reply to message #177663] Thu, 14 April 2005 21:10 Go to previous messageGo to next message
I see, however, what should I do to place a rotatable trianble in the middle
of a polyline connection?
"Randy Hudson" <none@us.ibm.com> д
Re: MidpointLocator problem [message #177774 is a reply to message #177766] Thu, 14 April 2005 21:26 Go to previous message
Problem solved using following subclass of MidpointLocator, thanks.
class MyMidpointLocator extends MidpointLocator {
public MyMidpointLocator(Connection c, int i) {
super(c, i);
public void relocate(IFigure target) {
PointList points = getConnection().getPoints();
RotatableDecoration arrow = (RotatableDecoration) target;
arrow.setLocation(getLocation(points));
arrow.setReferencePoint(points.getPoint(getIndex()));
"Hao Zhang" <bjzhanghao@21cn.com> д
Previous Topic:Custom Selection Drawing
Next Topic:Outline view selection doesn't do Properties
Current Time: Fri Jul 18 22:38:22 EDT 2025
Powered by FUDForum. Page generated in 0.05522 seconds
