Home » Modeling » Graphiti » How to initialize the diagram with some shapes
How to initialize the diagram with some shapes [message #1775213] Thu, 26 October 2017 07:51 Go to next message
When start my plug-in, I want to put some shapes in the diagram.How can I do?
Re: How to initialize the diagram with some shapes [message #1775274 is a reply to message #1775213] Fri, 27 October 2017 02:39 Go to previous messageGo to next message
I would suggest that you start with going through our tuturial, it explains all the steps that are required to build a graphical editor based on Graphiti. The tutorial can be found here:
http://help.eclipse.org/kepler/index.jsp?nav=%2F27_1
Michael
Re: How to initialize the diagram with some shapes [message #1775321 is a reply to message #1775274] Fri, 27 October 2017 11:21 Go to previous messageGo to next message
Sorry, Maybe my statement is not clear. When the plugin starts to run, the diagram is empty. Then, I can put shape on the diagram through palette. There is no any shape on the diagram. But I want the plugin to start running with some shapes on the diagram.
What should I do?
Re: How to initialize the diagram with some shapes [message #1775686 is a reply to message #1775321] Fri, 03 November 2017 09:27 Go to previous messageGo to next message
You should do that at the place where you create your diagram. in the tutorial this is done by the org.eclipse.graphiti.examples.common.ui.CreateDiagramWizard class which will just create an empty diagram.
HTH,
Michael
Re: How to initialize the diagram with some shapes [message #1775876 is a reply to message #1775686] Tue, 07 November 2017 09:11 Go to previous message
Previous Topic:Create visual container for GA's
Next Topic:Listeners on Shape
Current Time: Sun Jul 20 21:04:03 EDT 2025
Powered by FUDForum. Page generated in 0.04428 seconds
