Home » Modeling » EMF » [CDO] High Available CDO servers
[CDO] High Available CDO servers [message #1775672] Fri, 03 November 2017 01:58 Go to next message
Hi there,
Eike stated at Eclipsecon that CDO supports some mechanism like Server synchronisation (Master/Slave or Cluster?) to support high availability for CDO servers.
I didn't find any information about the features nor how to set it up in the CDO docs. Can someone point me somewhere?
Hauke
Re: [CDO] High Available CDO servers [message #1775781 is a reply to message #1775672] Mon, 06 November 2017 04:54 Go to previous message
Hi Hauke,
Five years ago I blogged about these two examples:
http://thegordian.blogspot.de/2012/11/use-online-data-offline.html
http://thegordian.blogspot.de/2012/11/fail-server-fail.html
They both refer to screencasts that might be interesting for you.
Unfortunately the example doesn't seem to run anymore. One problem is easy to fix in the SynchronizableRepository.notifyWriteAccessHandlers() method. It should be like this:
  public void notifyWriteAccessHandlers(ITransaction transaction, CommitContext commitContext, boolean beforeCommit, OMMonitor monitor)
    if (beforeCommit && commitContext.getNewPackageUnits().length != 0)
      for (InternalCDOPackageUnit packageUnit : commitContext.getNewPackageUnits())
        if (!packageUnit.isSystem())
          throw new IllegalStateException(
              "Synchronizable repositories don't support dynamic addition of new packages. Use IRepository.setInitialPackages() instead.");
    super.notifyWriteAccessHandlers(transaction, commitContext, beforeCommit, monitor);
The problem that comes up next seems to be in the example UI, but I currently don't have the time to investigate it. Maybe you have an idea ;-)
Cheers
Eike
Previous Topic:[xcore] generated code should implements an existing interface
Next Topic:Deleting Model Elements of an Dynamic Xcore Instance with Sample Reflective Ecore Model Editor
Current Time: Sun Jul 27 15:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.02841 seconds
