Re: Problem installing server runtime [message #178283 is a reply to message #177716] |
Wed, 30 August 2006 10:45  |
Originally posted by: moon.sun.com
Thank you
Could you tell me where can I set the Adapter type?
I can see all the Tomcat servers up to 5.5 listed in the server runtime, but
ALL of them have a red icon beside!
"Angel Vera" <gunfus@yahoo.com> wrote in message
news:ecfj6q$dci$1@utils.eclipse.org...
> There is Tomcat Adapters Types for starting from 3.2 all the way to 5.5,
> you
> must select the correct version of the Tomcat Adapter type that
> corresponds
> to the Tomcat server that you have installed. The code has a check that if
> the adapter type version that you selected doesn't match the version on
> the
> tomcat server in the file system, it will not enable the next button.
> "David" <moon@sun.com> wrote in message
> news:ec7aq2$oip$1@utils.eclipse.org...
>> Hi,
>> I am using Eclipse 3.2 with wtp-M-1.5.1-200608171632.zip using JDK 1.4.2.
>> When I try to config. Tomcat
FUDForum. Page generated in 0.07828 seconds
