Home » Modeling » TMF (Xtext) » Performance of Xtext editor(Editing in Xtext editor)
Performance of Xtext editor [message #1775263] Thu, 26 October 2017 23:53 Go to next message
Recently, I want to edit my DSL model(based on Xtext grammar) in Xtext Editor, then I found when i break the matched quotation marks, the function 'computeDamageRegion' will loop for a long time, which will block the UI. Like:
ApplicationInstance "simple.cps.app.AC0-0.inst0" {
ApplicationInstance "simple.cps.app.AC0-0.inst1" {
ApplicationInstance "simple.cps.app.AC0-0.inst2" {
allocatedTo "simple.cps.host.HC00.inst11"
When i delete a quotation(") in my model(About 150,000 Eobject, 250,000 References), the function consumed about 1,080,000ms and the during the time, the UI is blocked. Could you offer me any suggestion about this ?
Thanks in advance!
[Updated on: Fri, 27 October 2017 00:04] by Moderator
Re: Performance of Xtext editor [message #1775266 is a reply to message #1775263] Fri, 27 October 2017 01:15 Go to previous messageGo to next message
Do this strings look like qualified names in quotations by intention?
Re: Performance of Xtext editor [message #1775268 is a reply to message #1775266] Fri, 27 October 2017 01:28 Go to previous messageGo to next message
No, it is just the instance name. If I change the section in quotations, the above function won't consume a long time. After my debuggin, i find when breaking the matched quotations, it won't locate the affected region, and will loop until the end of the document, which need a long time. Am i right?
[Updated on: Fri, 27 October 2017 01:36] by Moderator
Re: Performance of Xtext editor [message #1775269 is a reply to message #1775268] Fri, 27 October 2017 01:34 Go to previous messageGo to next message
No I mean
"Bla { blubbern }" is valid inside this quotations
This makes error recovery bad and basically the whole file needs to be reprocessed
BTW edition an 200k line file is generally no a performant thing ....
Re: Performance of Xtext editor [message #1775271 is a reply to message #1775269] Fri, 27 October 2017 02:12 Go to previous messageGo to next message
Have you edited the file at the beginning and break the matched quotation(Like delete a quotation)? Just now, i use an model with about 280,000 line, and delete a quotation at the beginning, it is still bad performance(consumes about 10min).
I find edit postion is related with the comsumed time. If i delete a quotation at the end of file, i have no performance problem, buf if at the beggning, i will have bad performance("computeDamageRegion" consumes much time).
Re: Performance of Xtext editor [message #1775282 is a reply to message #1775271] Fri, 27 October 2017 03:54 Go to previous messageGo to next message
"BTW edition an 200k line file is generally no a performant thing ...."
Unless you break the file into paragraphs.
e.g. in many languages the grammar boils down to a tree of
paragraph := word* ('{' paragraph* '}' | ';')
When the braces fail to match, parsing is rubbish. Therefore the parser should have an outer paragraph partitioner doing its best bottom up and top down.
Most edits are paragraph preserving and so at most a couple of damaged paragraph(s) needs reparsing. If an edit destroys paragraph well-formedness, the user is better off with a fast display of just one or two error indicators for the bad paragraphing than a really slow obfuscation by thousands of secondary errors from unresolved symbols.
Ed Willink
Re: Performance of Xtext editor [message #1775289 is a reply to message #1775282] Fri, 27 October 2017 04:58 Go to previous messageGo to next message
Hi Ed,
Thanks for your reply!
But in general edition, user usually like to delete the content using 'Backspace' key, which will break matched quotation(as you said it destroy paragraph well-formedness), then cause the bad performance. So i think we should consider this scenario. and if i want to avoid this performance problem in my edtion(delete a quotation), Could you offer me a solution?
Re: Performance of Xtext editor [message #1775414 is a reply to message #1775269] Sun, 29 October 2017 23:50 Go to previous messageGo to next message
Hi Christian,
In your test, did your edition include deleting an quotation to break the balance of the quotations ? i use an model with about 280,000 line, and delete a quotation at the beginning of the text, it is still bad performance(consumes about 10min).
Hope for your reply!
Re: Performance of Xtext editor [message #1775419 is a reply to message #1775414] Mon, 30 October 2017 03:17 Go to previous messageGo to next message
????? Did you change the string rule?
Re: Performance of Xtext editor [message #1775420 is a reply to message #1775419] Mon, 30 October 2017 03:31 Go to previous messageGo to next message
No, i didn't change anything else, my operation is just delete an quotation(") instead of deleting the matched quotations(""),like changing "test" to "test
[Updated on: Mon, 30 October 2017 03:41] by Moderator
Re: Performance of Xtext editor [message #1775422 is a reply to message #1775420] Mon, 30 October 2017 03:42 Go to previous message
i tried to expolain you the same as ed did: deleting the quote changes the whole file.
thus i asked you is it wanted for you that
" bla { blubb }" is legal. if not try to change the string rule
Previous Topic:Exclude generated JAR files from indexing
Next Topic:Xbase doesn't bind overriden TypeConvertingCompiler
Current Time: Sat Jul 26 03:57:33 EDT 2025
Powered by FUDForum. Page generated in 0.06196 seconds
