Home » Modeling » ATL » ATL : multiple target from one source object
ATL : multiple target from one source object [message #1775154] Wed, 25 October 2017 09:07 Go to next message
I have some high-level actions that I must transform them to low-level ones (System calls).
One high-level action must be transformed into one or many system calls. For example, the high-level send must be transformed into the low levels system calls send, sendto end sendmsg.
Share is a system call, so, in my meta-model, it inherits from system call meta-classe.
rule Action2SystemCall{
from
Act : MM!Action
to
Sys : MM1!SystemCall()
rule Share2lowLevelSysCall {
from
Shr1 : MM!Share
to
Cnt1 : MM1!Sendto(),
Cnt2 :MM1!Send(),
Cnt3 :MM1!Sendmsg()
The problem is that the generated model is as follow :
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:target="www.target.com">
<target:PolicySet id="1">
<policy id="1">
<effect/>
<systemcall/>
</policy>
</target:PolicySet>
<target:Sendto/>
<target:Send/>
<target:Sendmsg/>
</xmi:XMI>
although the generated model must be like this
<policy id="1">
<effect/>
<systemcall xsi:type="target:Send"/>
<systemcall xsi:type="target:Sendto"/>
<systemcall xsi:type="target:Sendmsg"/>
</policy>
</target:PolicySet>
</xmi:XMI>
can anyone help me ?
Re: ATL : multiple target from one source object [message #1775327 is a reply to message #1775154] Fri, 27 October 2017 12:30 Go to previous messageGo to next message
See the documentation
Re: ATL : multiple target from one source object [message #1775856 is a reply to message #1775327] Tue, 07 November 2017 05:17 Go to previous messageGo to next message
Thank you for reply, but my problem still unsolved,
I don't understand how this function can help me.
Please help, I'm stuck-up
Re: ATL : multiple target from one source object [message #1775953 is a reply to message #1775856] Wed, 08 November 2017 09:42 Go to previous messageGo to next message
I tried to do :
rule Policy2Policy {
from
Pol : MM!Policy
to
Poli : MM1!Policy (
systemcall <- Pol.action,
effect <- Pol.effect
from
Shr1 : MM!Share
to
Cnt2 :MM1!Send(),
Cnt3 :MM1!Sendmsg()
but only one system call is considered, the other are outside the policy tag
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:target="www.target.com">
<policy id="1">
<effect effectValue="Allow"/>
</policy>
</target:PolicySet>
<target:Sendto/>
<target:Sendmsg/>
knowing that I need that all system call are in the pilicy tag like this
<policy id="1">
</policy>
</target:PolicySet>
Can any one help me
[Updated on: Wed, 08 November 2017 09:43] by Moderator
Re: ATL : multiple target from one source object [message #1775967 is a reply to message #1775953] Wed, 08 November 2017 11:17 Go to previous messageGo to next message
Only the first output element is inserted by default. The other output elements must be retrieved via thisModule.resolveTemp() (see link to manual above). You can then assign a Sequence{} of the three output elements to the systemcall property.
Re: ATL : multiple target from one source object [message #1776028 is a reply to message #1775967] Thu, 09 November 2017 08:25 Go to previous message
Thank you Dennis, I tried the methode resolveTemp(). It works very well when my source model contains only one policy. The ATL code is in the following:
from
Pol : MM!Policy
to
Poli : MM1!Policy (
systemcall <- MM!Action.allInstances()->collect(e | thisModule.resolveTemp(e,'Cnt1')),
systemcall <- MM!Action.allInstances()->collect(e | thisModule.resolveTemp(e,'Cnt2')),
systemcall <- MM!Action.allInstances()->collect(e | thisModule.resolveTemp(e,'Cnt3')),
But when I tried to insert another policy, the new policy get all the system call (x2) and the first policy does not contain any system call :
<target:PolicySet xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:target="www.target.com" id="1">
<policy id="1">
</policy>
<policy id="3">
</policy>
</target:PolicySet>
anyone have idea how to solve this problem
[Updated on: Thu, 09 November 2017 08:42] by Moderator
Previous Topic:Manage custome UML stereotypes out of Eclipse in ATL transformations
Next Topic:Need some suggestions about models to transform
Current Time: Sun Jul 27 13:41:00 EDT 2025
Powered by FUDForum. Page generated in 0.04713 seconds
