Home » Language IDEs » ServerTools (WTP) » Server runtime template for WebSphere 5.1
Server runtime template for WebSphere 5.1 [message #177472] Fri, 18 August 2006 13:38 Go to next message
Originally posted by: RGuschin.computel.ru
Hi all, is Subj exists for eclipse 3.2 somewhere? There is only
templates for WebSphere 6.0 runtime.
Rodion
Re: Server runtime template for WebSphere 5.1 [message #177480 is a reply to message #177472] Fri, 18 August 2006 15:27 Go to previous messageGo to next message
Originally posted by: gunfus.yahoo.com
I am assuming you are refering to the Server Adapters, which is the type of
server that you can create. If that is what you are referring to, then the
answer is no. There is other server types that you can use, Tomcat... etc..
check out the Link at the top left of the Server Creation window.
"Rodion Guschin" <RGuschin@computel.ru> wrote in message
news:ec4tuk$o4t$1@utils.eclipse.org...
> Rodion
Re: Server runtime template for WebSphere 5.1 [message #177496 is a reply to message #177480] Fri, 18 August 2006 17:46 Go to previous messageGo to next message
Originally posted by: graymagi.gmail.com
Thanks for reply,
Yes, that i was talking about. It`s strange, that for WebSphere 6.0
there is such adapter, but none for v5.1. I thought that some third
party plug-ins may supply this feature - any suggestions?
Rodion
>> Rodion
Re: Server runtime template for WebSphere 5.1 [message #177503 is a reply to message #177496] Fri, 18 August 2006 18:04 Go to previous messageGo to next message
The adaptors were supplied to the wtp project. WTP only providided the APIs
for the implementation.
For extended support for WebSphere you may need to look into IBM's tooling
Rational Application Developer.
"Rodion Guschin" <graymagi@gmail.com> wrote in message
news:ec5cgb$1op$1@utils.eclipse.org...
> Thanks for reply,
> Rodion
of
the
etc..
> >> Rodion
Re: Server runtime template for WebSphere 5.1 [message #177536 is a reply to message #177503] Sat, 19 August 2006 05:54 Go to previous message
I already have Rational Application Developer. It's overweight with
functionality I don`t need and also based on 3.1 version of eclipse
(plug-ins that I really need won't work with that version). May be there
is a way to extract plug-ins responsible for interactions with WebSphere
5.1 from IBM RAD and make them work with eclipse 3.2? All i need - is
ability to deploy/redeploy applications on existing installation of
WebSphere 5.1 server from IDE.
Rodion.
>> Thanks for reply,
>> Rodion
> of
> the
> etc..
>>>> Rodion
Previous Topic:NoClassDefFoundError for Web Service interface
Next Topic:I can not update my EJB-project
Current Time: Sat Jul 26 08:47:31 EDT 2025
Powered by FUDForum. Page generated in 0.03917 seconds
