Home » Newcomers » Newcomers » Error sun/misc/BASE64Encoder(Error Encoding Android Application)
Error sun/misc/BASE64Encoder [message #1774185] Wed, 11 October 2017 08:40 Go to next message
Hi all,
I'm a new Java developer on Android platform and i have a problem: Under Eclipse Oxigen, during a compilation of a simple Android project test program composed by an EditText box, a Button and Text box, without a Java code, only layout objects,
afther populating, with this three objects, the layout section, if I click on Run/Run As/Android Application, Eclipse Oxigen show me this error:
Errors occurred during the build.
Errors running builder 'Android Package Builder' on project 'Risponditoreinterattivo'.
My Operative System is Windows 7 Ultimate, Installed Java jdk-9_windows-x64, Installed Eclipse Oxigen 1 win64, Installed Android ADT adt-bundle-windows-x86_64-20130729 and upgraded. Patched Eclipse Oxigen configuration eclipse.ini file to work with Java SE SDK 9. Downloaded and installed Android development objects on Eclipse Oxigen.
All is working except the encoding... And from here i could'nt move. What can I do?
Thank you very much.
[Updated on: Wed, 11 October 2017 10:53] by Moderator
Re: Error sun/misc/BASE64Encoder [message #1774220 is a reply to message #1774185] Wed, 11 October 2017 15:17 Go to previous messageGo to next message
Is that the full error message? sun.* packages are specific to Sun JVMs, and I wouldn't expect to find them on Android of all places.
Re: Error sun/misc/BASE64Encoder [message #1774978 is a reply to message #1774185] Mon, 23 October 2017 03:14 Go to previous messageGo to next message
I think your JRE (Java Run-time Environment) does not match your android SDK.
You have to install jre1.8, and select it in eclipse [Preferences] -> [Java] - [Installed JREs].
[Updated on: Mon, 23 October 2017 21:39] by Moderator
Re: Error sun/misc/BASE64Encoder [message #1774981 is a reply to message #1774185] Mon, 23 October 2017 03:34 Go to previous messageGo to next message
This is a picture which shows eclipse JRE preferences.
Re: Error sun/misc/BASE64Encoder [message #1782464 is a reply to message #1774185] Fri, 23 February 2018 12:25 Go to previous message
Thx a lot ... I gonna try what you told me and I'll tell you the result. thx
Previous Topic:Test cases are not running due to TestNG exception.
Next Topic:Good day
Current Time: Sat Jul 26 13:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.07385 seconds
