Home » Modeling » EMF » "a registered resource factory is needed" outside the generated editor
"a registered resource factory is needed" outside the generated editor [message #377406] Thu, 01 May 2003 13:12 Go to next message
I have an EMF model which is running perfectly in the generated editor.
Now I want to load the model from a file in some code outside of the
generated editor. I get the exception below. For loading the file I
perform the steps as in the generated editor (see below).
How do I register the required resource factory?
Thanks for any hints,
Chris
=== code snippet starts here ===
List factories = new ArrayList();
factories.add(new ResourceItemProviderAdapterFactory());
factories.add(new ModelItemProviderAdapterFactory());
adapterFactory = new ComposedAdapterFactory(factories);
BasicCommandStack commandStack = new BasicCommandStack();
editingDomain = new AdapterFactoryEditingDomain(adapterFactory,
commandStack);
String inputFile = "f:/workspace/eva/Releases13.model";
Resource resource = editingDomain.loadResource
(URI.createFileURI(inputFile).toString());
=== code snippet ends here ===
=== console output starts here ===
java.lang.RuntimeException: Cannot create a resource for
'file:/f:/workspace/eva/Releases13.model'; a registered resource factory
is needed
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:282)
at
org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain.load Resource(AdapterFactoryEditingDomain.java:284)
at eva.fs.tests.AllTests.loadFile(AllTests.java:202)
at eva.fs.tests.AllTests.buildEd(AllTests.java:162)
at eva.fs.tests.EvaEditionTest.setUp(EvaEditionTest.java:24)
at junit.framework.TestCase.runBare(TestCase.java:125)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:270)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:161)
Re: "a registered resource factory is needed" outside the generated editor [message #377407 is a reply to message #377406] Thu, 01 May 2003 14:35 Go to previous messageGo to next message
Originally posted by: shu.us.ibm.com
Chris,
You need to register resource factory.
You can use call
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put
And this is sample codes for xmi format file which is using
XMIResource interface.
("*", <--- your file extension
new XMIResourceFactoryImpl() <--- the class to resource factory
public Resource createResource(URI uri)
XMIResource xmiResource = new XMIResourceImpl(uri);
return xmiResource;
You can provide your own resource factory class and resource class to
handle
your own file (if it is not xmi or xml file).
For more infomation, please refer to EMF users guide, session 3.4.2 and
3.4.3.
Shu
> Chris
> commandStack);
> is needed
> at
> at
> at
> at
> at
Re: "a registered resource factory is needed" outside the generated editor [message #377408 is a reply to message #377407] Fri, 02 May 2003 06:40 Go to previous messageGo to next message
That helped.
I was wondering why I don't have to do this when I am using the
generated editor plugin. But the plugin seems to register the resource
factories during plugin initialization - which is missing in my
stand-alone app.
Next time I will do RTFM.
Thanks a lot,
Chris
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774817 is a reply to message #377408] Thu, 19 October 2017 18:33 Go to previous messageGo to next message
I want to go from an xtext model to its EMF model but i got this exception can anyone help me to solve this problem.
thanks in advance .
  • Attachment: Capture.PNG
    (Size: 65.65KB, Downloaded 459 times)
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774848 is a reply to message #1774817] Fri, 20 October 2017 09:47 Go to previous messageGo to next message
I'm not sure what you really mean. There is an *.ecore file associated with Xtext, optionally manually entered, optional autogenerated. Use ctrl-shift-R to locate it by name.
If you want to see a model perspective of the *.xtext in the Sample Ecore Editor. Sorry that stopped working a couple of years ago.
Ed Willink
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774888 is a reply to message #1774848] Fri, 20 October 2017 16:06 Go to previous messageGo to next message
actually i have the xtext model and i want to transform it 's EMF Model and parse the graphe generated using java in order to add some nodes or update it or delete it om my EMF Model , but i get this error
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774910 is a reply to message #1774888] Sat, 21 October 2017 02:06 Go to previous messageGo to next message
Your visual snippet has so many things that make me uncomfortable I'm not sure where to start.
But first, do not attach a new problem to a 14 year old thread. Software moves much to fast for there to be any sensible prospect that your new problem is a continuation.
Do not use visual snippets. Your code cannot be cut and paste as a mini repro. Your exceptions are hideously truncated forcing major guessing. Why not cut and paste so that we see it all and Google searches can find similar content?
I am a Windows user, but I never use "\" in code. "/" works fine in all C/Java based software.
I suspect that your problem is "file:///". I would need to read the specification to be sure what it actually means. URI.createFileURI is so much easier.
Ed Willink
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774930 is a reply to message #1774910] Sat, 21 October 2017 10:20 Go to previous messageGo to next message
this is what happen when i remove the file:///
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: c
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:25)
at org.xtext.example.Test.loadScript(Test.java:40)
at org.xtext.example.Test.main(Test.java:65)
Caused by: java.net.MalformedURLException: unknown protocol: c
at java.net.URL.<init>(Unknown Source)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:199)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.xtext.resource.XtextResourceSet$1.createInputStream(XtextResourceSet.java:298)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 4 more
    (Size: 23.20KB, Downloaded 322 times)
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774931 is a reply to message #1774930] Sat, 21 October 2017 10:30 Go to previous messageGo to next message
this is my code :
package org.xtext.example;
import java.io.ByteArrayInputStream;
import java.io.IOException;
import java.io.InputStream;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.xtext.resource.IResourceFactory;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.resource.XtextResourceSet;
import com.google.inject.Guice;
import com.google.inject.Injector;
import projetm.ProjetmPackage;
public class Test {
public static void loadScript() {
Injector injector = new ProjetStandaloneSetupGenerated().createInjectorAndDoEMFRegistration();
ResourceSet resourceSet = injector.getInstance(ResourceSet.class);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put
new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put
(ProjetmPackage.eNS_URI,
ProjetmPackage.eINSTANCE);
//resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
Resource r1 = resourceSet.getResource(URI.createURI("file:///C:\\Users\\kawtar NAJI\\runtime-EclipseXtext\\TesteEMF\\test.projet"),true);
Resource r2 = null;
try {
r1.load(null);
r2 = resourceSet.createResource(URI.createURI("file:///C:\\Users\\kawtar NAJI\\runtime-EclipseXtext\\TesteEMF\\test1.xmi"));
System.out.println(r1.toString());
r2.getContents().add(r1.getContents().get(0));
r2.save(null);
EcoreUtil.resolveAll(r1);
} catch (IOException e) {
e.printStackTrace();
Test.loadScript();
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774932 is a reply to message #1774931] Sat, 21 October 2017 11:47 Go to previous messageGo to next message
"URI.createFileURI is so much easier."
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1774933 is a reply to message #1774931] Sat, 21 October 2017 11:48 Go to previous messageGo to next message
As was already suggested a \ in a URI is a bad idea because it is NOT a path separator in a URI, it's a path separator only on Windows and only as far as java.io.File is concerned. Generally when using file-based access, use URI.createFileURI(file.getAbsolutePath())) to create the URI from the java.io.File. Make sure it's absolute.
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1791510 is a reply to message #1774933] Sun, 01 July 2018 09:26 Go to previous messageGo to next message
Hi guys,
I try to execute an ATL program progromatically. ( the transfromation of a bpmn model into an ecore model). the execution of the program generate the following exceptions.
Metamodel contains several classifiers with same name: DocumentRoot
Metamodel contains several classifiers with same name: di::DocumentRoot
org.eclipse.m2m.atl.core.ATLCoreException: Error loading Models/process_1.bpmn: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///C:/Users/lenovo/Desktop/Nouveau%20dossier%20(5)/tuto1/Models/process_1.bpmn, 2, 370)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:70)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:84)
at com.BPMN2BPMNSUC.loadModels(BPMN2BPMNSUC.java:161)
at com.BPMN2BPMNSUC.main(BPMN2BPMNSUC.java:94)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///C:/Users/aljia/Desktop/Nouveau%20dossier%20(5)/tuto1/Models/process_1.bpmn, 2, 370)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.m2m.atl.core.emf.EMFInjector.inject(EMFInjector.java:65)
... 3 more
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'definitions' is not found or is abstract. (file:///C:/Users/aljia/Desktop/Nouveau%20dossier%20(5)/tuto1/Models/process_1.bpmn, 2, 370)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2251)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObjectFromFactory(XMLHandler.java:2242)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1339)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
... 5 more
Any helps pleaase.
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1791511 is a reply to message #1791510] Sun, 01 July 2018 09:33 Go to previous messageGo to next message
Assuming that "Metamodel contains several classifiers with same name" is a surprise to you, you almost certainly have a metamodel schizophrenia problem; only load each distinct metamodel by one mechanism; see recent posts / Google.
Ed Willink
Re: " java.lang.RuntimeException: Cannot create a resource for 'file:///C:\Users\kawtar NAJI\ru [message #1791514 is a reply to message #1791511] Sun, 01 July 2018 11:22 Go to previous message
In the end, this is the EMF forum, not the ATL forum so you might ask on that specific forum instead:
https://www.eclipse.org/forums/index.php?t=thread&frm_id=241
Previous Topic:Problem Reloading Genmodel. `<>` operator is not allowed for source level below 1.7
Next Topic:[EMF Validation] No maintainer of project?
Current Time: Sat Jul 26 11:20:22 EDT 2025
Powered by FUDForum. Page generated in 0.10993 seconds
