Importing a Metamodel in XText 2.12. [message #1774868] |
Fri, 20 October 2017 13:27  |
I tried by all means for the last two days to find a post that would allow me to solve my problem, but alas here I am.
The problem I'm trying to fix is simple enough: I'm trying to import an ecore metamodel in XText instead of generating it. Resources such as this and others seem to be deprecated for XText 2.12
Unfortunately, the proposed solution online seem to be deprecated. Therefore, I opted to follow the instructions in the XText documentation, namely the section for importing metamodels, by creating the default XText "MyDsl" project.
MyDsl.text:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=ID '!';
GenerateMyDsl.mwe2:
module org.xtext.example.mydsl.GenerateMyDsl
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.example.mydsl"
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
eclipsePluginTest = {
enabled = true
createEclipseMetaData = true
code = {
encoding = "windows-1252"
lineDelimiter = "\r\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "org.xtext.example.mydsl.MyDsl"
fileExtensions = "mydsl"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
As expected, after generating the XText artifacts, I get a MyDsl.ecore and MyDsl.genmodel written in "./model/generated".
I then proceeded to change the "generate" statement to an "import" in MyDsl.text:
import "http://www.xtext.org/example/mydsl/MyDsl"
Model:
Greeting:
And registered my "MyDsl.genmodel", as explained in documentation through the workflow file GenerateMyDsl.mwe2:
var rootPath = ".."
Workflow {
configuration = {
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
enabled = true
code = {
//added this line
referencedResource = "platform:/resource/org.xtext.example.mydsl/model/temp/MyDsl.genmodel"
serializer = {
validator = {
The "./model/temp" folder is just a copy of "./model/generated". I then go on to successfully generate the XText artifacts once again, but some of the generated artifacts contain compilation errors, namely some manifest files complaining "org.xtext.example.mydsl.myDsl.impl,
org.xtext.example.mydsl.myDsl" do not exist in this plug-in.
My intuition tells me this problem has something do to with registering an ePackage for the meta model, but I'm not sure exactly how to go about that.
Is there a quick fix that can be made so that I can import an ecore metamodel file in XText?
In case it factors in the analysis, I'm currently using XText 2.12 and Eclipse Oxygen
Thanks in advance
Re: Importing a Metamodel in XText 2.12. [message #1774878 is a reply to message #1774869] |
Fri, 20 October 2017 15:00  |
If you want to see a family of editors with imported/manual metamodels and no warnings have a look at the GIT\org.eclipse.ocl\plugins\org.eclipse.ocl.xtext.* projects.
If you want to see some workflows to build the Ecore models and editors see GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.build\src\org\eclipse\ocl\examples\build\GenerateCSModels.mwe2 and GIT\org.eclipse.ocl\examples\org.eclipse.ocl.examples.build\src\org\eclipse\ocl\examples\build\GenerateAllEditors.mwe2
Ed Willink
FUDForum. Page generated in 0.04849 seconds
